Finding The Effect of Several Electrics Fields
  • Thread starter Thread starter Bashyboy
    Fields
The discussion revolves around calculating the total electric field generated by four charged particles positioned at the corners of a square. The user initially calculated the electric fields from each particle but obtained an incorrect total magnitude. Key points include the importance of accurately determining the distance between the particles and the point of interest, particularly for particle B, which requires using the diagonal distance of √2a instead of a units in both directions. Clarifications emphasize the need to resolve the electric field components correctly while maintaining the proper distances. The conversation highlights common pitfalls in electric field calculations and the significance of precise measurements in physics problems.
Bashyboy
Four charged particles are at the corners of a square of side a as shown in the figure below. (Let A = 5, B = 2, and C = 7.)
Well, I first found the electric due to each particle individually:
\vec{E_A}=k_e\frac{5q}{a^2}\widehat{i}
\vec{E_B}=k_e \large[ \frac{2q~cos(45°)}{a^2}\widehat{i}+\frac{2q~sin(45°)}{a^2}\widehat{j}]
\vec{E_C}=k_e\frac{7q}{a^2}\widehat{j}
Summing the effects of the each electric field together:
\vec{E_{tot}}=k_e \large[(\frac{5q+2q\cos{45°}}{a^2}\widehat{i}+(\frac{2q \sin{45°}+7q}{a^2}\widehat{j}
After simplifying, I found the magnitude of the electric field at point q, that the three particles create, to be 10.58 \cdot \frac{q}{a^2}; however, the true answer is, 9.59 \cdot \frac{q}{a^2} What did I do wrong?
You did not include a diagram or describe what you are asked to find.
Sorry. I just attached one.
OK, what's the distance between B and q?
Wouldn't it be \sqrt{2}a?
I figured it would be better to resolve the electric field of B into its components.
Right.
Nothing wrong with that, but you must use the correct distance to calculate the field.
Well, to get from point B to point q, don't I have to go a units to right and a units north? What are the correct distances?
You just gave the correct distance in your earlier post. Use it!
Oh I see, I am mixing the idea of resolving charges and distances together.
