Finding the Equation of a Plane in R3 Using Intersection Points and Distances
  • Context: Graduate
  • Thread starter Thread starter xzardaz
    Camera
The discussion revolves around finding the equation of a plane in R3 based on the intersection points of three lines that pass through the origin and the distances between these intersection points. Participants explore the mathematical relationships and equations necessary to derive the plane's equation, considering the geometric properties of the points involved.
  • One participant presents a problem involving three lines in R3 and seeks to find the equation of a plane intersecting these lines at specific points, given certain distances between those points.
  • Another participant suggests using the intersections to determine the normal vector of the plane and proposes a method involving the cross product of vectors formed by the intersection points.
  • There is a discussion about the representation of lines and how to solve for the parameter t to find the intersection points on the plane.
  • One participant expresses confusion about how to utilize the distances h and w in conjunction with the line equations to find the points of intersection.
  • Further clarification is sought regarding the relationship between the line equations and the points on the plane, with a focus on how to derive the coordinates of the intersection points.
Participants do not reach a consensus on the best approach to solve the problem, and multiple viewpoints on how to derive the plane's equation and the intersection points are presented. The discussion remains unresolved regarding the specific steps to take.
Participants acknowledge the complexity introduced by the quadratic equations related to the distances between points, which complicates the solution process. There are also references to the need for normalization of vectors and the potential existence of multiple solutions for the plane's equation.
xzardaz
Hello, I have a simple(or not?) math problem:
I have equations of 3 lines in R3 trought the origin:
line l1:
1*x+β1*y+γ1*z=0
2*x+β2*y+γ2*z=0
line l2:
3*x+β2*y+γ3*z=0
4*x+β3*y+γ4*z=0
line l3:
5*x+β4*y+γ5*z=0
6*x+β5*y+γ6*z=0
I know every λ, β and γ - they are real constants.
I also have a plane δ and :
l1 intersects δ in point p1,
l2 intersects δ in point p2,
l3 intersects δ in point p3
I also know:
...the distance between p1 and p2 = h
...the distance between p2 and p3 = w
...p1, p2 and p3 form a right triangle with right angle at p2 (h2+w2=(p1p3)2)
I want to find the equation of δ in terms of λ, β, γ, h and w
_______________________________
it should be easy to find the equation of the plane if I find the points p1, p2 and p3
I think I should compose a system, containing:
...the first six equations(which are linear, so it should be easy to solve with matrices),
...the equation for right angle in R3: w2+h2=(p1p2)2,
...the two equations for distances w and h: h2=(p1x-p2x)2+(p1y-p2y)2+(p1z-p2z)2 and w2=(p2x-p3x)2+(p2y-p3y)2+(p2z-p3z)2
There are 9 equations with 9 unknowns (3 points, each with 3 coordinates) - it should be solvable.
Have you got any ideas how to solve this? If there weren't 3 quadratic equations it would be easy.
*I know that there should be 2 planes, matching the conditions - one that I've drawn(see the image) and the other is at the opposite side of the origin. I think the two roots of the quadratic equations should find them.
Hey xzardaz.
Try using the intersections to get the normal of the plane and use one of the points as a point on the plane.
Basically a line is represented by L(t) = a*(1-t) + (b-a)*t where the line passes through points a and b.
Now if you solve for t for all the lines you build a normal by considering n = (p2-p1) X (p3-p1) which you normalize and then use the relationship n . (r - r0) = 0 where n is what you solved, r0 = p1, and r is a general point on the plane.
I don't think I fully understand you. Can you give me some references ?
If I solve L(t) = a*(1-t) + (b-a)*t for all the lines, I can't get the points, because there are infinite number of points matching the equations. How do I use w and h ?
You can solve for t by using the fact that L(t) = point on plane for some t and then re-arrange to get the value of t.
Happy new year,
L(t)=a(1-t)+(b-a)t\\
L(t)=p1x(1-t)+(p2x-p1x)t
L(t)=p1y(1-t)+(p2y-p1y)t
L(t)=p1z(1-t)+(p2z-p1z)t
L(t)=p2x(1-t)+(p3x-p2x)t
L(t)=p2y(1-t)+(p3y-p2y)t
L(t)=p2z(1-t)+(p3z-p2z)t
Is that what you mean ? If so, how do I find p1, p2 and p3 ?
What you have is basically L_1(t) = p1 = a1*(1-t1) + (b1-a1)*t1, L_2 = a2*(1-t2) + (b2-a2)*t2 and so on.
You extrapolate your variables in terms of the t's by relating the different forms of the line equations together.
The normal is calculated in terms of (p3-p1) X (p2-p1) and this will give the normal to the plane with point p1 on the plane.
  • · Replies 17 ·
