Finding the fault in this circuit (UV lamp controller)
engnrshyckh
TL;DR
Guys this circuit and shematic is of UV lamp controller.. It burns sometime as shown in figure can someone tell the reason?
  • Schematic of a push-pull transistor oscillator with two D1616A transistors Q2 and Q4, base resistors R6 and R7 at 560 ohm, capacitor C6 0.068uF/100V CBB, transformer T1 labelled TEPC ER420mH, and output connectors P2 and P3 with C1 and C2 at 15pF/3000V.
  • Photo of a small green printed circuit board with two white connectors on the left, two blue capacitors labelled CY1 and CY2, a yellow-taped transformer, a resistor, an orange capacitor and a dark, scorched inductor, plus a fuse and a connector on the right.
Is this a one time failure? From your description, 'sometimes it burns', does this mean it has happened with a replacement controller, too? Do you have UV lamp specifications you can let us see?
engnrshyckh said:
Summary:: Guys this circuit and shematic is of UV lamp controller.. It burns sometime as shown in figure can someone tell the reason?
Several possibilities:
  • Load is too heavy (wrong lamps? high humidity?))
  • Running without a load
  • C6 bad
  • Transformer has shorted turn(s)
  • A resistor has changed value (looks like they have overheated, replace 'em)
  • Supply voltage is (occassionally?) too high
  • High ambient temperature
  • Bad design (parts under-rated for the use)
The above is roughly in order of probability. (unless it is a third-world design with a very low price; then the bad design is most likely. :wink:)
Likely a few more "maybe's."
From the looks of them, those transistors have failed shorted. Which could be temperature related (overload, shorted transformer, shorted C6) or from voltage spikes (running no-load, or open C6). Could also be a bad resistor.
Cheers,
Tom
@engnrshyckh -- The schematic looks a bit amateurish. Is this a home-brew circuit? Did you design it? If not, where did you get it and the schematic?
Circuit schematic of a transistor push-pull driver with two D1616A transistors Q2 and Q4, each with a 560 ohm resistor, a 0.068uF/100V CBB capacitor, and a transformer winding labelled TEP with taps 1, 5 and 6, all returning to GND.
