Finding the momentum of the each balls
  • Thread starter Thread starter Niles
    Balls Momentum
The discussion revolves around calculating the total momentum of a baseball and tennis ball system, and the kinetic energy of a bullet fired into a ballistic pendulum. For the first question, participants emphasize the need to find the momentum of each ball to determine the system's total momentum. In the second question, confusion arises regarding the velocity of the bullet and pendulum after the collision, with participants noting discrepancies in their calculations. The conversation highlights the importance of considering energy conservation principles, specifically that some kinetic energy is lost upon impact, while mechanical energy is conserved afterward. Ultimately, the focus is on applying momentum and energy conservation laws to solve the problems accurately.
Niles
There are two questions.
1) A baseball, m=0.045 kg, moves in +y-direction with v = 5 m/s. a tennisball is moving in the -x direction with speed of 2m/s. Wat is the magnitude and direction of total momentum in the system?
2) A 0.01 kg rifle bullet is fired with v = 500 m/s into a ballistic pendulum of mass 5 kg suspended from a cord 0.6 m long. Find the height of the pendulum, the initial kinetic energy of the bullet and the kinetic energy of the bullet and pendulum.
1) I have no idea, beside finding the momentum of the each balls.
2) I tried using p_bullet + p_pendulum = (m_bullet + m_pendulum)u, but I get u = 0,998 m/s, which i believe is incorrect.
1. Look up the definition of the total momentum of a system (of particles).
2. Why do you believe it is incorrect?
1) great, will do!
2) It seems very small. Must I use that KE_bullet = KE_bullet_and_pendulum?
Niles said:
1) great, will do!
If I do what I wrote in about KE, I get that v_(pendulum and bullet) = 22,34 m/s. But when using p_1 = p_2, I get v = 0,9980 m/s. How is this?
Think potential energy. EDIT: For the KE of bullet+pendulum: You have figured out the velocity of the two together. Now given the velocity and mass, find KE.
So KE_bullet = PE_(bullet and pendulum), and from there i find the height.
I'm sorry, but I don't get the last thing you wrote.
Forget about the KE of the bullet...some of it is lost when it hits the block. But mechanical energy is conserved after the bullet embeds itself in the block.
Just said in a round-about way that KE = 0.5mv2 :wink: You know the mass of the bullet+pendulum, and you have figured out its (initial) velocity. (Although, the question doesn't mention it, I'm assuming that it is initial KE that is to be found)
Great, thanks!
