Finding the pressure and temperature of a compressed monatomic gas
The discussion focuses on calculating the final pressure and temperature of a compressed monatomic ideal gas using the adiabatic process equations. The initial conditions include a volume of 3 m3, a temperature of 300 K, and a pressure of 1 x 105 Pa. After compression to a volume of 2 m3, the final pressure is determined to be 1.97 x 105 Pa, and the final temperature is calculated as 355.23 K. The conversion factor of 22.4 L/mol is clarified as the volume of one mole of an ideal gas at STP, which is essential for determining the number of moles in the gas.
  • Understanding of the ideal gas law (PV = NkbT)
  • Knowledge of adiabatic processes in thermodynamics
  • Familiarity with the concept of degrees of freedom and the adiabatic index (gamma)
  • Basic understanding of standard temperature and pressure (STP) conditions
  • Study the derivation and application of the adiabatic process equations
  • Learn about the ideal gas law and its implications in thermodynamic calculations
  • Research the significance of degrees of freedom in different gas types
  • Explore variations in STP definitions and their impact on gas calculations
This discussion is beneficial for students studying thermodynamics, particularly those focusing on gas laws and adiabatic processes, as well as educators teaching these concepts in physics or chemistry courses.
Jenkz
A monatomic ideal gas initially has a volume of 3 m^3, a temperature of 300 K and
is at a pressure of 1x 10^5 Pa. It is compressed adiabatically and quasi-statically to a
volume of 2 m^3. Calculate its final pressure and temperature.
Po(Vo ^gamma)= P1(V1^gamma)
PV= NKbT
degrees of freedom (nd)= 3
gamma = nd+2/ nd = 5/3
Vo = 3m^3 ; V1= 2m^3
P0 = 1x10^5Pa ; P1 = ?
The new pressure ; P1 = 1.97 x 10^5 Pa
Re-arrange to get T= P1V1 / N Kb
N = V0 / 22.47 x 6.02 x10^23 (avogadro's number) = 8.036 x10 ^25
So T = 355.23K
I understand the method, but I do not understand where the value of 22.47 comes from. But i think that V0/22.47 is to find the number of moles. Help please?
22.4 is the volume (in liters) of one mole of an ideal gas at STP. So yes, it converts from volume to moles.
Ar ok, thank you very much. I'll keep that figure in mind in the future. :)
It converts from moles to liters at STP. Unfortunately the problem specifies the initial temperature is 300K so the factor is more like 24.9 L/mol.
Special bonus item - standards bodies do not agree on what STP conditions are. But the informal standard is 0C/1 atm.
10K
  • · Replies 60 ·
10K
  • · Replies 20 ·
