Finding the ring-singularity of a rotating black hole
The discussion revolves around identifying the coordinates of the ring singularity in a rotating black hole described by the Kerr metric. Participants explore the mathematical properties of the Kerr metric, particularly focusing on the determinant of the metric in Boyer-Lindquist coordinates and its implications for singularities. The conversation includes technical calculations, coordinate transformations, and theoretical considerations regarding singularities in general relativity.
  • One participant presents the Kerr metric in Boyer-Lindquist coordinates and seeks to find the coordinates where the determinant of the metric approaches infinity, which is associated with the ring singularity.
  • Another participant discusses the relationship between different coordinate systems and suggests that the determinant of the metric may not reliably indicate actual singularities due to coordinate dependence.
  • A later reply emphasizes the need for a coordinate-independent method to confirm the existence of singularities, referencing a method from a textbook that involves the Riemann curvature tensor.
  • Several participants discuss the definitions of variables in the equations, such as the meaning of \( \Delta \) and \( \rho^2 \) in the context of the Kerr metric.
  • One participant shares their calculations of the determinant and expresses confusion about how to interpret the results in terms of a ring in spherical coordinates.
  • Another participant suggests that the discussion may be more suited for a different section of the forum, indicating a potential overlap with homework or coursework questions.
Participants express differing views on the reliability of the determinant of the metric for identifying singularities, with some advocating for coordinate-independent methods. The discussion remains unresolved regarding the best approach to locate the ring singularity and the interpretation of the determinant's results.
Limitations include the dependence on the choice of coordinate system and the unresolved nature of the calculations presented. Some assumptions about the nature of singularities in rotating black holes are also not fully explored.
TheMan112
I'm trying to find the coordinates where the determinant of the Kerr metric goes towards infinity. This should give the ring singularity of a Kerr (rotating) black hole. So, I'm starting out with the standard form Kerr metric in Boyer-Lindquist coordinates:
[tex]ds^2=\frac{\Delta}{\rho^2}(dt-a sin^2 \theta d\phi)^2-\frac{sin^2\theta}{\rho^2}((r^2+a^2)d\phi-a dt)^2-\frac{\rho^2}{\Delta}dr^2-\rho^2d\phi[/tex]
Then I break out the terms [tex]dt^2, dr^2, d\theta^2, d\phi^2[/tex] and [tex]dt d\phi[/tex], this gives the metric:
[tex]g_{ab} = \left(\begin{array}{cccc} \frac{\Delta-a^2 sin^2\theta}{\rho^2} & 0 & 0 & \frac{2a sin^2\theta (r^2+a^2-\Delta)}{\rho^2} \\ 0 & -\frac{\rho^2}{\Delta} & 0 & 0 \\ 0 & 0 & \rho^2 & 0 \\ \frac{2a sin^2\theta (r^2+a^2-\Delta)}{\rho^2} & 0 & 0 & \frac{sin^2 \theta (\Delta a^2 -(r^2 + a^2)^2)}{\rho^2} \end{array} \right)[/tex]
Calculating the determinant of this matrix in Maple gives the expression:
[tex]det(g_{ab})={\frac{1}{\delta}}\left(- \left( \sin \left( \theta \right) \left( \Delta\,{a}^{2}-{r<br /> }^{4}-2\,{r}^{2}{a}^{2}-{a}^{4} \right) \right) ^{2}\Delta+ \left( <br /> \sin \left( \theta \right) \left( \Delta\,{a}^{2}-{r}^{4}-2\,{r}^{2}{<br /> a}^{2}-{a}^{4} \right) \right) ^{2}{a}^{2} \left( \sin \left( \theta<br /> \right) \right) ^{2}+4\,{a}^{2} \left( \sin \left( \theta \right) <br /> \right) ^{4}{r}^{4}+8\,{a}^{4} \left( \sin \left( \theta \right) <br /> \right) ^{4}{r}^{2}[/tex]
[tex]-8\,{a}^{2} \left( \sin \left( \theta \right) <br /> \right) ^{4}{r}^{2}\Delta+4\,{a}^{6} \left( \sin \left( \theta<br /> \right) \right) ^{4}-8\,{a}^{4} \left( \sin \left( \theta \right) <br /> \right) ^{4}\Delta+4\,{a}^{2} \left( \sin \left( \theta \right) <br /> \right) ^{4}{\Delta}^{2}[/tex][tex])[/tex]
Are my calculations correct? And how can I find the coordinates where it goes towards infinity in an analytical way? I'm not even sure how to plot the determinant on a computer given I'm not entirely used to Boyer-Lindquist coordinates.
Edit: Pardon the "bad" thread title, I pushed the submit button rather prematurely.
Consider coordinate systems [itex]\left\{x^\alpha \right\}[/itex] and [itex]\left\{x^{\alpha'}\right\}[/itex]. The components of the metric with respect to the two coordinate systems are related by
[tex] g_{\alpha \beta} = \frac{\partial x^{\gamma'}}{\partial x^\alpha} \frac{\partial x^{\delta'}}{\partial x^\alpha} g_{\gamma' \delta'}.[/tex]
Thus,
[tex] \det \left[ g_{\alpha \beta} \right] = \det \left[ \frac{\partial x^{\gamma'}}{\partial x^\alpha} \right] \det \left[ \frac{\partial x^{\delta'}}{\partial x^\alpha} \right] \det \left[ g_{\gamma' \delta'} \right],[/tex]
so the determinant of the metric could be unproblematic in one coordinate system and zero or infinite in another coordinate systems because of a problem with coordinates, i.e., the because the determinant of the matrix of coordinate partials is zero or blows up.
Consequently, it is not sufficient to use the determinant of the metric to find real singularities.
Out of curiosity, what books are you using for your study of general relativity?
Thus,
Yes, but shouldn't the ring singularity be a singularity regardless of the coordinate system used? Just like the point-singularity in a non-rotating black hole. Which coordinate system would you use if not Boyer-Lindquist?
I'm using Ray D'Inverno's "Introducing Einstein's Relativity" btw. If you have the book, the equation I'm starting out from is (19.27).
Regards
Regards
My point is that while a coordinate-based method can be useful for identifying *potential* singularities, it cannot pin down with certainty that something is an "actual* singularity. Some other coordinate-independent method is needed.
On page 254, d'Inverno gives a method that works for Kerr - the blowing up of the coordinate-independent quantity
[tex]R^{abcd} R_{abcd}.[/tex]
I have a similar problem and just wondering
is Δ=r2+a2-2Mr
where
a = angular momentum/Mass
M =Mass of the black hole
r= what radius? radius of the black hole or radius of the "ring"
ρ2=r2+a2+cos2θ
You've revived a bit of an old thread here but for the record, r is the distance from the centre of the object of gravity to the observer, M is the gravitational radius of the object (M=Gm/c^2), a is the spin parameter of the object (a=J/mc). Incidentally a/M will provide you with a unitless spin parameter between 0 and 1, 0 being static, 1 being maximal (i.e. a=M).
The second equation should be written [itex]\rho^2=r^2+a^2cos^2\theta[/itex] and represents the oblate nature of a rapidly spinning object ([itex]\theta[/itex] being the angle between the z axis (i.e. pole) and the line of approach).
The radial http://en.wikipedia.org/wiki/Killing_vector_field" (named after W. Killing) for a Kerr black hole can be expressed as-
[tex]g_{rr}=\frac{\rho^2}{\Delta}[/tex]
becoming null at [itex]r_\pm=M\pm\sqrt{M^2-a^2}[/itex] where [itex]r_+[/itex] is the outer event horizon and [itex]r_-[/itex] is the inner event horizon.
The azimuth Killing vector field can be expressed as-
[tex]g_{tt}=\frac{\Delta-a^2sin^2\theta}{\rho^2}[/tex]
becoming zero at [itex]r_e=M+\sqrt{M^2-a^2cos^2\theta}[/itex], the ergosphere.
My problem is as follows:
"Calculate the determinant of the Kerr metric. Locate the plac where it is infinite. (In fact, this gives the "ring"-singularity och the Kerr black hole, which is the only one)
I got the determinant to :
7a2r4sin4θ+7a4r2sin4θ-8a2r2sin4θ-16Ma2r3sin4θ+16M2a2r2sin4θ-2Ma4rsin4θ+2a2r4sin2θ+a4r2sin2θ+r6sin2θ+2Ma4rsin2θ-4M2a2r2sin2θ-2Mr2sin2θ
all devided by r2 + a2 - 2Mr
and I talked to my prefessor and he told me that the answer should be the equation of a ring in spherical coordinates, I have all this in Boyer-Lindquist coordinates I believe, and according to wikipedia
{x} = \sqrt {r^2 + a^2} \sin\theta\cos\phi
{y} = \sqrt {r^2 + a^2} \sin\theta\sin\phi
{z} = r \cos\theta
(http://en.wikipedia.org/wiki/Boyer-Lindquist_coordinates)
I don't get it to be an eq of a ring (or circle) .. please help =)
  • · Replies 20 ·
  • · Replies 43 ·
  • · Replies 16 ·
