Finding the units in an algebraic equation for velocity
  • Thread starter Thread starter Kennedy
    Units Velocity
The discussion focuses on determining the units of constants a and b in the velocity equation v = at^3 + bt^4, where velocity is expressed in meters per second (m/s). To ensure that both terms on the right side of the equation yield consistent units of m/s, the units of a and b must be carefully selected. Participants emphasize the importance of matching units, noting that the powers of time (t) must be accounted for in the calculations. The goal is to find units for a and b that allow for the cancellation of terms, resulting in the correct dimensional analysis. The conversation highlights the significance of understanding unit relationships in algebraic equations.
Kennedy
During a short interval of time the speed v in m/s of an automobile is given by v = at^3 + bt^4 , where the time t is in seconds. The units of a and b are respectively:
(a) m⋅s^2 ; m⋅s^4 (b) s^3/m; s^4/m (c) m/s^2 ; m/s^3 (d) m/s^3 ; m/s^4 (e) m/s^4 ; m/s^5
None
I have not a single clue, and I'm assuming that there is a trick to this that I'm not getting. I know that the velocity is measured in m/s, but I don't understand how finding the units of a and b is even possible.
What do you know about the relationship between the units of terms in an equation where you are summing the terms? Can you add apples to oranges? :smile:
Nope, I know that you can only add apples to apples, or oranges to oranges, which means that both a and b need to be measured with the same units. Since this is an equation for velocity, I would assume that the units of the right hand side would also need to be m/s.
Think again. The terms also contain powers of t. What are the units associated with t?
Right. So you need to choose the units of a and b so that their terms (including their t's) both work out to m/s.
So, I'm looking for units of a and b for which all of the s's in the numerator cancel, and there is only one s left in the denominator, and one m in the numerator?
Sounds like a plan!
gneill said:
Sounds like a plan!
Thank you!
