MHB How Do You Calculate P(12) for a Polynomial Given Specific Conditions?
  • Thread starter Thread starter Saitama
    Value
To calculate P(12) for the polynomial P(x) of degree 11, it is established that P(x) equals 1/(x+1) for x values from 0 to 11. A suggested approach involves defining g(x) as (x+1)P(x) - 1, which maintains the polynomial's properties while allowing for the determination of the coefficient a by substituting x = -1. The discussion emphasizes the use of the Lagrange Interpolating Polynomial method to derive the necessary values. Ultimately, the correct formulation and calculation will yield the value of P(12).
Saitama
Problem:
Let $P(x)$ be a polynomial of degree 11 such that
$$P(x)=\frac{1}{x+1}\,\,\,\text{for}\,\,\,x=0,1,2,\cdots 11$$
Then find the value of P(12).
Attempt:
I have done this kind of problem long before but I don't exactly remember the process.
I think it was something like this:
Define $g(x)=P(x)-\frac{1}{x+1}$, then
$$g(x)=P(x)-\frac{1}{x+1}=ax(x-1)(x-2)\cdots (x-11)$$
But I don't think the above is correct. I don't have the value of $a$.
Any help is appreciated. Thanks!
Mathematics news on Phys.org
Pranav said:
Problem:
Attempt:
I'm afraid that You have to use the Lagrange Interpolating Polynomial...
$\displaystyle P(x) = \sum_{j=1}^{n}\ p_{j}(x)\ (1)$
... where...
$\displaystyle p_{j} (x) = y_{j}\ \prod_{k=1,\ k \ne j}^{n} \frac{x - x_{k}}{x_{j} - x_{k}}\ (2)$In Your case is n=12, $x_{k}=k - 1$, $y_{k} = \frac{1}{k}$...
Kind regards$\chi$ $\sigma$
Pranav said:
Problem:
Attempt:
You are thinking along the right lines, but you would do better to define $g(x) = (x+1)P(x) - 1$. You would still have $g(x) = ax(x-1)(x-2)\cdots (x-11)$, but this way you can find $a$ by putting $x=-1$.
Thank you Opalg! :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
