Finding the velocity of a rock thrown vertically on Mars
The correct velocity of a rock thrown vertically on Mars is 6.28 m/s, as derived from the function H(t) = -1.86t² + 10t - 8.14. The user initially calculated a derivative of -314 m/s due to an error in factorization. The correct approach involves directly differentiating the polynomial rather than using the limit definition of the derivative. The user should review basic calculus principles, particularly the polynomial derivative formula.
  • Understanding of calculus, specifically derivatives
  • Familiarity with polynomial functions
  • Knowledge of limit definitions in calculus
  • Ability to factor quadratic equations
  • Review the derivative of polynomial functions in calculus
  • Practice factoring quadratic equations accurately
  • Learn to apply the limit definition of derivatives effectively
  • Explore calculus resources that cover basic theorems and formulas
Students studying calculus, particularly those struggling with derivatives and polynomial functions, as well as educators seeking to clarify these concepts for their students.
member 731016
Please see below
Please see below
For this problem,
The answer is ##6.28 m/s##, however, I got ##-314 m/s## and I am not sure what I have done wrong.
My working is,
##H'(t) = \lim_{t \rightarrow 1} \frac{H(t) - H(1)}{t - 1}##
##H'(t) = \lim_{t \rightarrow 1} \frac{-1.86t^2 + 10t -8.14}{t - 1}##
##H'(t) = \lim_{t \rightarrow 1} \frac{(93t - 407)(t - 1)}{t - 1}##
##H'(t) = \lim_{t \rightarrow 1} 93t - 407 = -314##
Could someone please point out what I have done wrong?
Many thanks!
ChiralSuperfields said:
Homework Statement: Please see below
Relevant Equations: Please see below
For this problem,
My working is,
Many thanks!
Are line 1 and line 2 equal?
-Dan
-Dan
Thank you for your reply @topsquark !
I believe the factorization is correct (I used my graphics calculator to find the roots). The derivative formula I am using is ##H'(t) = \lim_{t \rightarrow 1} \frac{H(t) - H(1)}{t - 1}##
Many thanks!
Many thanks!
So, you are saying that
##-1.86 t^2 + 10 t - 8.41 = (93 t - 407)(t - 1)##
FOIL out that RHS, please.
-Dan
-Dan
Thank you for your reply @topsquark!
True, they are not equal. I need to multiply the right hand ride by a factor of -1.86/93 to make the equations equal. This gives the correct solution.
Many thanks!
For this problem,
My working is,
Many thanks!
No need to calculate H(1), or resort to a calculator (or the quadratic formula) to factorise the result:<br /> \begin{split}<br /> \lim_{t \to 1} \frac{H(t)- H(1)}{t - 1} &amp;= \lim_{t \to 1} \frac{10t - 1.96t^2 - (10 \times 1 - 1.86 \times 1^2)}{t - 1} \\<br /> &amp;= \lim_{t \to 1} \frac{10(t-1) - 1.86(t^2 - 1^2)}{t-1} \\<br /> &amp;= \lim_{t \to 1} \frac{10(t-1) -1.86(t + 1)(t - 1)}{t-1} \\<br /> &amp;= \lim_{t \to 1} \left(10 - 1.86(t + 1)\right) \\<br /> &amp;= 10 - 2 \times 1.86.\end{split} But you can just differentiate H directly. \begin{split}<br /> H&#039;(t) &amp;= 10 - 2 \times 1.86 t \\<br /> H&#039;(1) &amp;= 10 - 2 \times 1.86.<br /> \end{split}
I am surprised that you have to go to the basic definition of the derivative. The formula for the derivative of a polynomial would be covered very early in any calculus class. You should check whether you are expected to know that formula at this point. If so, you should review basic calculus and make the theorems and formulas in it second nature to you.
  • · Replies 43 ·
14K
  • · Replies 25 ·
