Finding the x-Intercept of a Perpendicular Line Passing Through a Given Point
  • Thread starter Thread starter MrNeWBiE
To find the x-intercept of the line perpendicular to the line joining points (1, 1) and (3, 4) that passes through (1, 2), the slope of the original line is calculated as 3/2. The slope of the perpendicular line is determined to be -2/3, leading to the equation y = (-2/3)x + 8/3. Setting this equation to zero to find the x-intercept results in the solution (4, 0). The final answer is confirmed as (4, 0).
MrNeWBiE
Find the x-intercept of the line that passes through the point (1; 2) and perpendicular to the
line joining (1; 1) and (3; 4):
I want to confirm my steps if it's right ,,,,
M=(4-1)/(3-1)= 3/2
y-1=3/2(x-1) ====> y=(3/2)x-1/2
perpendicular = m1xm2=-1 ====> m2=-2/3
y-2=-2/3(x-1) ====> y=(-2/3)x+4/5
making it one equation
(3/2)x-(1/2)=(2/3)x+(4/3)
x=11/13
x=11/13
I am not sure what you did here. I am assuming you were trying to combine the equation of the first line with the second line. If so, you have calculated the point of intersection of the two lines, which is not what the question has asked for. The question asked you for the x-intercept of the line.
aha ,,,
so I should not combine them ,,,
(-2/3)x+4/5 = 0 ?
and the answer will be (10/13,0)
Looks good to me!
ops ,,,
I had a mistake in y=(-2/3)x+4/5 ,,, should be y=(-2/3)x+8/3
the answer is (4,0) ,,,
btw the for your helping
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
