First Order ODE With v = y' Substitution
checkmatechamp
8t^2 * y'' + (y')^3 = 8ty' , t > 0
I tried using the substitution v = y' to get:
8t^2 * v' + v^3 = 8tv
I rewrote it in the form 8t^2 * dv/dt + v^3 = 8tv, and then moved the v^3 to the other side to get 8t^2 * dv/dt = 8tv - v^3.
I then multiplied both sides by dt to get:
8t^2 dv = (8tv - v^3) dt
Try to get it in exact form.
8t^2 dv - (8tv - v^3) dt = 0
8t^2 dv + (8tv + v^3) dt = 0
But when I test for exactness, it doesn't work, because 16t doesn't equal 3v^2 + 8t. Did I mess up somewhere, or is there some way to continue?
First write the equation as 8t^2dv+ (v^3- 8tv)dt= 0.
Yes, that is not an "exact equation" because the derivative of 8t^2, with respect to t is 16t while the derivative of v^3- 8tv with respect to v is 3v^2- 8t. They are not the same. However, since everything here is a power of t and v, I would try powers of t and v as an integrating factor- multiply the both sides of the equation by t^nv^m to get 8t^{n+2}v^mdv+ (t^nv^{m+3}- 8t^{n+1}v^m)dt= 0. Do there exist values of m and n such that this is an exact equation?
Have you studied the Bernoulli equation? If so, if you write it as ##8t^2v' - 8tv = -v^3## you will recognize that dividing by ##v^3## and letting ##u = v^{-2}## will lead you to a linear first order DE.
Alright, let's see.
8t^2v' - 8tv = -v^3
v' - v*t^-1 = -v^3 / (8t^2)
v^-3 * v' - v^-2 * t^-1 = -1 / (8t^2)
Bernoulli form is v^-n * v' + p(t)*v^(1-n) = q(t)
So that means n = 3 in this case.
Use a substitution u = v^(1 - 3)
u = v^-2 and u' = -2v^-3*v'
So then substituting back in, we get:
-0.5u' - u/t = -1/(8t^2)
So then I multiply both sides by -2 and get:
u' + 2u/t = 2/(8t^2)
u' + 2u/t = 1/(4t^2)
Integrating factor is e^(∫(2/t)dt)
Integrating factor is e^(2*ln(t))
e^(ln(t^2)), which becomes t^2
Multiply both sides by the integrating factor.
t^2 * u' + 2tu = 1/4
So t^2 * u = ∫(t^2*0.25t^-2)
t^2*u = ∫0.25 dt
t^2*u = 0.25t
u = 0.25t / (t^2)
u = 0.25/t + c
u = v^-2, so v^-2 = 0.25/t + c
Flip both sides.
v^2 = 1/(0.25/t + c)
v^2 = (t / c1t + 0.25)
v = √(t / c1t + 0.25)
Since v = y', that means y = ∫√(t / c1t + 0.25). Am I on the right track once I solve that integral?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
