First Order System's Time Constant
9 replies · 20K views
yanaibarr
Hello,
I have a question on a the units of a first order system's time constant.
If i have a first order system the basic transfer function will be:
K/(tau*s+1)
where K is the Gain, and tau is the system's time constant.
tau's units, according to what I've learned, are [sec].
but aren't the s plane's units in [rad/sec] (s=jw+sigma)?
That means that tau should be given in [sec/rad] to match the "1"-'s units in the transfer function.
I know that rad can be considered "unitless" but when dealing with actual numbers it matters if the system's time constant is 1 [sec] or 1[sec/rad]= 2*pi [sec].
My question is specifically about the units of tau in the transfer function,
not when it is used in the decay rate of e (e^(-t/tau)), there it has to be sec.
I'll appreciate a clarification.
Thanks
tiny-tim said:
tau is always in seconds …
No, one may use any unit for tau. For exponential decay, Ae^(-t/tau), the exponent (-t/tau) should be unit-less.
Thanks for he replay.
One more question about it,
if tau's units should be seconds, then the s-plane units should be Hz [1/s].
According to what I've learned, the s-plane's units are [rad/sec] (s=jw+sigma).
Can i take the s-plane's units as Hz?
I tried working with an actual differential equation, and according to it the s-plane's units will always be [1/sec], because the s represents the derivative.
If it's so, when do i use the [rad/sec] units and when [Hz] in the s-plane?
Thanks,
Yanai barr
yanaibarr said:
tiny-tim said:
tau is always in seconds …Thanks for he replay.
According to what I've learned, the s-plane's units are [rad/sec] [tex](s=j\omega+\sigma)[/tex].
Thanks,
Yanai barr
[tex]\omega[/tex] has units of [tex]\frac{rad}{sec}[/tex] (s = jw+sigma) , Hz has units of [tex]\frac{1}{s}[/tex] so the connection you made between the derivative, 1/s and, Hz for the s domain is correct.
tiny-tim said:
sorry, i don't know, i haven't come across the s-plane :redface:
The s-plane is what u get after using the Laplace Transform.
viscousflow said:
Thank u for the reply ,
but Hz [1/s] and omega's units [rad/s] are not the same, u should divide\multiply it by 2*pi.
This is exactly my question, the units don't match (according to the theory I've learned).
In theoretical problems it doesn't matter, but when i use actual numbers i need to decide how to use the data, and how to convert the units accordingly.
Yanai Barr
I've stumbled at the same problem. All learning materials seem to expose the concept but none gives example with exact units.
So, if I want a frequency break at 1 Hz, should I write 1/(s+1) or 1/(s+2Pi)? Second seems more plausible. However, when Laplace-transfromed, it gives e-2pi t meaning that time constant is T = 1/2pi. Yet, I'm customed that periods are measured in seconds rather than seconds per radian. I mean that 2pi is not usually a part of period. But, wikipedia article on time constant does not clarify what are the units.
https://www.physicsforums.com/showthread.php?t=516891"
