Fixing Fortran DO Command Errors for Visual Fortran (f90)
  • Context: Fortran
  • Thread starter Thread starter zandria
    Fortran
4 replies · 5K views
zandria
I am working with visual Fortran (f90 I believe)
I have the following program and it says that I have 2 errors. I have narrowed it down to having something to do with my loop statement in bold. Is there something wrong that I'm not getting?
program exercise1
implicit none
integer :: limit, f1, f2, f3
read*, limit
f1 = 1
if (limit >= 1) then
print*, f1
end if
f2 = 1
if (limit >= 2) print*, f2
do i= 3, limit
f3 = f1 + f2
print*, f3
f1 = f2
f2 = f3
end do
end program exercise1
nevermind, figured it out. I did not define "i" as a variable in my list of integers
Remove (delete) the statement: implicit none
DO NOT REMOVE THE IMPLICIT NONE STATEMENT
Having that in forces the user to explicitly define their variables. Removing that statement to get a program to compile will nearly always cause problems later down the line.
Simply put: fix it right the first time.
Without the IMPLICIT NONE, if you mis-spell the name of a variable once, the compiler doesn't catch it for you, as an undeclared variable. Instead, it cheerfully allocates a new variable with that name, which has no connection with the variable you meant to use. Your program compiles "successfully," but when you run it, it either produces incorrect results or crashes with a run-time error that can be very difficult to track down.
