Average Times Coin Combination Appears in 10 Letters
  • Thread starter Thread starter ParisSpart
Flipping a fair coin 10 times generates a sequence of letters C (for crown) and L (for the other side). The discussion centers on calculating how often the sub-word "CCLLCC" appears in these sequences. It is established that there are 1024 total combinations of 10 letters, and "CCLLCC" can fit into the sequence in 5 distinct positions. For each of these positions, there are 16 combinations for the remaining letters, leading to a total of 80 occurrences of "CCLLCC." The probability of "CCLLCC" appearing in a random sequence of 10 letters is therefore approximately 0.0781.
ParisSpart
Flipping a fair coin 10 times. This creates a word of length 10 of the letters C and L. On average how many times it appears in this sub-word CCLLCC?
C=crown and L= the other side of coin
i think that if i count CCLLCC in 10 letters of C and L we will have 5 times but how i will find the average?
If 6 of the letters are "CCLLCC" then the other four letters can be either "C" or "L". There are 2^4= 16 ways to do that. But you also need to allow for where in the set of 10 letters those letters occur.
I assume by "sub-word", you require that the letters "CCLLCC" occur together. Do you see that there are 5 places the initial C can be?
Hello, I'm not quite sure if I'm right as I'm still a novice in the world of math. It's been a while since I have taken my prob/stats class.
__ __ __ __ __ __ __ __ __ __
There are 2 ways either C or L for each of the spaces above. So, the total number of ways for spelling out a 10 letter word is 2*2*2*2... = 2^{10} = 1024
There are 5 ways for CCLLCC to occur inside some of the 10 letter words. One of them looks like this:
C C L L C C __ __ __ __
The spaces containing CCLLCC are all "locked in". So, there are 4 spaces left for choices.
2*2*2*2 = 2^{4} = 16
There are 5 ways in which CCLLCC can occur because you can just shift CCLLCC one space to the right each time to get a new word that contains CCLLCC.
Possible ways of getting a word with CCLLCC in it: 5*16 = 80
I'm not sure what you meant by "average", so I guess you want the probability as well. \frac{80}{1024} = 0.0781
Once again I'm not a 100% sure, but I hope it helps you a bit. :P
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
