Floating and Sinking in a Liquid
  • Thread starter Thread starter Messiri
    Floating Liquid
A container can float in a liquid if the liquid's density is less than that of the container. For a metallic container to float in water, it must be filled with a liquid that has a density lower than water, such as ethanol. The relationship between the densities of the container and the liquid determines whether it will float or sink. If the container's density is greater than water, it will sink regardless of the liquid inside. Thus, the key factor for floating is ensuring the combined density of the container and the liquid is less than that of the surrounding medium.
Messiri
This seems to be a relatively simple question, yet I'm not sure of the answer.
A balloon filled with helium gas floats in air. If I submerged a balloon or container in a liquid (e.g. water), is there a liquid with which I can fill the container so as to make it float to the surface. What kind of a liquid would this be? What kind of properties must it have in relation to the water? Specifically this liquid should be the reason the container floats - without the liquid the container sinks.
Looking forward to your responses.
What would be in the container if the liquid were not in it? Air? Hard vacuum? The same material that the container walls are made of?
Anything that would make it sink.
Essentially my question is...if I have a (lets say metallic container) is there a liquid that can make the container float in water (or other liquid)?
Basically, what relation between the two media mentioned above (that don't include air) determines whether or not the container will float?
If the container is light enough, then any liquid less dense then water would result in the container floating, such as ethanol.
Likes 1 person
Whether or not an object, any object, will float or not in a medium depends on the density (mass/volume) of the object as well as that of the medium. If the density of the object is lesser than that of the medium, it will float. If greater, it will sink. If the densities are equal, the object will remain where it is.
If your container is sinking without any liquid in it, it's density is more than the density of water. In that case, no liquid you fill can make it float. It will always sink.
Likes 1 person
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
