Flow Past Sphere at High Re - Velocity Behavior
The simulation of airflow around a sphere at 450 m/s reveals a significant decrease in velocity ahead of the sphere, likely due to shock wave formation. This phenomenon occurs because the flow speed exceeds the speed of sound, resulting in a bow shock rather than an attached oblique shock. The observed cut plot indicates a pressure increase in the green zone, correlating with the velocity drop. The blunt shape of the sphere contributes to this flow behavior. Understanding these dynamics is crucial for accurate simulations in high-speed aerodynamics.
redpepper303
Hello,
I'm currently working on simulations in Solidworks of the flow of air (v = 450 m/s)
around a sphere (radius = 1.5 cm). The results have been used in a cut plot
representing the velocity in the x direction. The image is similar to this one:
https://www.llnl.gov/str/December01/gifs/Naka3.jpg
(Purple is high velocity and red is low velocity)
I was wondering why the velocity suddenly decreased so far in front of the
sphere and so spaced out (green zone), and then increases again.
Thank you for any answer!
That looks a lot more like a plot of pressure than a plot of velocity to me. At any rate, I don't know what conditions these simulations were run at, but 450 m/s is likely above the speed of sound, so the reason you see a sudden increase in pressure (and decrease in velocity) is because a shock wave is going to form. It happens out in front of the sphere because the sphere is rather blunt, and so you get a bow shock instead of an attached oblique shock.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
