Fluid dynamics and particulate diffusion question
The discussion revolves around calculating the number of particulates entering a smaller, closed tube connected to a larger tube with a constant laminar fluid flow saturated with particles. The challenge lies in the 90-degree junction and the non-constant flow conditions, complicating the use of standard diffusion equations. The model suggests treating the smaller tube as a constant-pressure system influenced by the flow dynamics from the larger tube. There is a need to clarify the configuration of the tubes to understand the flow mechanics better, particularly whether the connection forms a T or an L shape. Overall, the problem requires advanced modeling techniques, potentially using software like COMSOL, to analyze the interaction between the fluid flow and particulate diffusion effectively.
ArriFerrari
I have two cylindrical tubes connected at a 90 degree junction. One tube has a constant flow of a laminar fluid going through it and the fluid is saturated by a soluble particulate with a known concentration. The other tube has a much smaller radius, initially has no particles and is closed at the unconnected end.
How do I find the number of particulates that enter the smaller, closed tube? What equations would be most suitable for this situation?
Interesting problem. I would model the smaller tube as a constant-pressure system with a fixed high-concentration source of particles at one end, perhaps similar to thermal diffusion (constant heat source at one end).
Were this one straight tube split by some diaphragm with a high concentration on one side and zero on the other and the diaphragm were suddenly removed, this would be easily solved analytically using the diffusion equation. However, I imagine there is no analytical solution here on account of the 90-degree bend and the fact that you assume there is some flow going on as well.
That's a fair point; I assumed the smaller tube was initially full of (incompressible) solvent devoid of solute.
That is a fair assumption. In the experiment, it is. The only reason I can't use a simple diffusion equation is that constant flow. This is actually only a first step though, I need to find how much of the solute gets in the smaller tube when there is a non-constant flow. We can still assume that the laminar, non-compressible fluid is going straight down the larger tube, like water in a pipe. But it is driven by a rhythmic pressure fluctuation (like a heartbeat). I have access to COMSOL, but very little experience setting up this sort of thing.
How exactly do you have a steady flow if one end is capped off? That would seem to be impossible. Is the second tube connected so as to form a T with the first tube and allow a constant flow through the first tube or is it an L as you originally described?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
