jmz34
- 29
Firstly, the whole question is below, for now I need help on parts of the question- I've included it all for clarity and just in case I have further problems.
An equilibrium ring of isothermal fluid orbits a star at radius R. In the plane of the ring, mechanical equilibrium results from a balance of centrifugal force and gravitational force of the central object; normal to the ring (ie.vertically) equilibrium is between the vertical component of the gravitational force of the central object and the vertical pressure gradients in the ring of gas. Show that in the limit that the ring thickness H<<R the vertical density stratification in the ring is Gaussian and determine the e-folding length in terms of the gas temperature and the angular velocity of the ring, w. Hence determine an upper limit to the temperature such that the ring is thin (H<<R) and calculate this temperature if the ring's radius is that of the Earth's orbit around the sun.
My attempt:
I first derived the angular velocity as a function of distance within the ring. I did this by balancing the centripetal force with the gravitational force between a fluid element and the star and then writing R->R+H and eliminating H^2 and higher order.
Next I wrote down the equation of hydrostatic equilibrium (setting u=0 in the momentum equation, giving):
(-1/p)dP/dr=-g where p=density, P=pressure and g is the gravitational acceleration
I can see that at the innermost fluid element, g=GM/r^2 by Gauss' law but within the fluid the elements inside the circle centred at the star and lying on the plane of the ring will contribute to g as well, and I don't know how to construct a 2D analogue of Gauss' theorem.
I would be very grateful if someone could check if my thinking is correct and if it is, help me find this 2D analogue of Gauss' theorem.
Thanks alot.
My attempt:
Thanks alot.
