Calculating Instantaneous Flow in a Siphon - Help Needed!
Lorna18
Fluid mechanics (urgent help)
i got stuck in the middle... guess i could do with some help!
A siphon has uniform cross sectional area of 10^(-3) sq.m consider that water has no viscisity. A tank has height upto 80m. half of it contains water. the end of the siphon inside the tank is 20m above the base. the other end of the siphon fully pre-filledwith water is 30m above the base. find the instantaneous rate of flow out of water from the tank.
take g=9.8m/sec^2.
a) 14 l/sec b) 19.8 l/sec c) 28 l/sec d) no out flow, rather in flow will occur.
can't exactly understand how to approach the problem!
take g=9.8m/sec^2.
Hi Lorna18! :smile:
Hint: if you want to use a Bernoulli's equation , draw a streamline with both ends at the same pressure. :wink:
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
