Fluid mechanics: Some elementary concepts
The discussion focuses on fundamental concepts in fluid mechanics, contrasting particle and field descriptions through Lagrangian and Eulerian formalism. Key topics include the definitions of particle trajectories, streamlines, material curves, and streak lines, along with derivations related to inviscid flow such as Bernoulli's equation and various theorems. There is a debate about the inclusion of advanced topics like Luke's principle and Clebsch flow in introductory tutorials, with suggestions for a more engineering-oriented approach. The importance of foundational principles such as fluid kinematics, integral balance equations, and flow behavior at different Reynolds numbers is emphasized. Overall, the conversation highlights the balance between advanced theoretical concepts and practical applications in fluid mechanics education.
arildno
Dearly Missed
In this thread, I will explore some elementary concepts in fluid mechanics, starting with the distinction between a particle description and a field description (Lagrangian vs. Eulerian formalism).
I will continue by distinguishing between the concepts of particle trajectories, streamlines, material curves and streak lines.
Furthermore, I'll look into the basic derivations we may make with these concepts in inviscid flow, namely Bernoulli's equation, Crocco's theorem, Kelvin's theorem, Helmholtz' theorem for vortex lines,and the helicity theorem.
Lastly, I'll look into the assumptions behind irrotational, i.e, potential flow, the generalized potential flow known as the Clebsch flow, and the elegant principle known as Luke's principle of variation.
Quite a bit more to follow in a while..
I am interested seeing some of this stuff if you're still interested in going through it.
If you finally do this stuff, honestly I think your point of view should be a more "engineering oriented" one. I have been studying fluid mechanics during 3 years when undergrad and now doing the Ph.D. in aerospace engineering, and I have never heard about Luke's principle nor Clebsch flow. I'm pretty sure they exist and they are important, but I think they are not the kind of stuff you should include in a tutorial for giving the big picture of this science.
To my understanding a better guideline could be something like:
i) Fluid Kinematics: Eulerian description, Pathlines, Streamlines, Streaklines.
ii) Integral Balance Equations: Continuity, Momentum, Total Energy, Kinetic Energy, Enthalpy and Entropy. Incompressibility assumption. Vorticity Equation.
iii) Differential forms. Reynolds Transport Theorem.
iv) Non dimensional Relevant Parameters.
v) Flow at low Reynolds. Poiseuille and Couette Flows. Stokes Equations. Oseen's approximation. Hydrodynamic Lubrication.
vi) Flow at high Reynolds. Boundary Layer. Blausius Similarity Solution. Bernoulli Equation.
vii) Compressible Flow. Rankine-Hugoniot equations. Shock Waves and Expansion Fans.
viii) Classical Hydrodynamics. Surface Gravity Waves. Shallow Water equations. Flow over obstacles.
viii) Stratified Flow. Bousinessq approximation. Buoyancy frequency. Internal Waves.
ix) Turbulent Flow. RANS equations. Reynolds stress tensor. Auschtag Viscosity coefficient. Closure problem. Boussinesq approximation. Round Turbulent Jet.
Good ideas. I had quite forgotten about this thread.
Clausius2 said:
... I have never heard about Luke's principle nor Clebsch flow. I'm pretty sure they exist and they are important, but I think they are not the kind of stuff you should include in a tutorial for giving the big picture of this science.
Luke's variational principle is quite elegant and worth to mention especially when potential theory is on the scene. Even, variational calculus itself is a must for anyone interested in fluid mechanics. Finite element people are quite good at dealing with the variational form of the partial differential equations.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
