Flyback diode on solenoid slows solenoid retract time
The discussion revolves around the impact of a flyback diode on the retract time of a solenoid in an electrical engineering application. Participants explore the effects of the diode on voltage spikes and response times, particularly in time-sensitive applications. The conversation includes suggestions for circuit modifications to improve performance and considerations for using PWM control.
  • One participant notes that the retract time of the solenoid increases significantly with the flyback diode installed, from 25 ms to over 100 ms, which poses a problem for their customer's application.
  • Another participant suggests using a resistor in series with the switching path and a capacitor in parallel to help manage current changes and reduce holding time while keeping the diode in place.
  • A different participant proposes that a small resistor in series with the diode could dissipate energy faster, although this seems counterintuitive.
  • There is mention of using a zener diode to provide a more predictable time to open by maintaining a constant di/dt until the armature starts to move.
  • One participant shares their experience with a similar issue in a mail sorting project and suggests testing with current and voltage probes to better understand energy dissipation in the circuit.
  • Another participant raises the idea of using an H-bridge to improve turn-off performance, indicating a potential alternative approach to the problem.
  • Several participants discuss the importance of understanding the solenoid's inductance, hold current, and resistance for proper circuit design.
Participants express various suggestions and hypotheses regarding circuit modifications, but there is no consensus on a single solution. Multiple competing views on how to address the issue remain, and the discussion is unresolved.
Participants mention the need for specific values for resistors and capacitors based on the solenoid's characteristics, indicating that the discussion is dependent on these parameters. There is also uncertainty regarding the exact behavior of the solenoid and the effects of different circuit configurations.
Electrical engineers and designers working with solenoids, particularly in applications requiring precise timing and control, may find this discussion relevant.
Emach
Hello,
I'm an electrical engineer dipping my foot into solenoids as part of a project here at work.To monitor the position of the solenoid's armature I have a linear pot installed. My is issue revolves around a flyback diode installed across a DC solenoid I am testing. I am low side switching the solenoid with a cheap DPDT relay. Without the flyback diode installed I see massive negative voltage spikes across V(coil) as I would expect. With the diode installed, no large negative spike occurs. Problem solved right?? Wrong, with the flyback diode installed the retract time, specifically the time after turning off the relay but before I see movement of the armature, jumps from 25 ms without the diode to over 100 ms with the diode. My customer's application is very time sensitive, they won't be happy with a +100 ms delay before the armature begins to move when powering off the solenoid. I am also assuming that my customer will want to use a FET for switching the solenoid on and won't like a 100V surge when turning it off, making the diode and something else to speed up the response time a part of their final solution. Any suggestions would be greatly appreciated! Sorry for the PDF, work copier defaults into PDFs.
Early in my career, I worked on a project for mail sorting and found the same thing. You will need to use a resistor in series with the switching path and a cap in parallel with the resistor. The cap should be of sufficient value to allow the current change to quickly snap the the solenoid in the power on state then ramp the current down to the resistor value limited amount. The resistor limited amount should be the holding current which should be much less than the initial closing current. The diode still needs to be in place, but the smaller current should reduce the holding time by a significant amount. You will need to determine the values based on your current, voltage and coil resistance.
I *think* a small resistor in series with the diode will dissipate the energy faster. Seems counter-intuitive though.
energy to be got rid of is LI2/2
rate of energy dissipation is VI
in a resistor V and I are in proportion
in a zener they are not
so a zener should give a constant di/dt until the armature starts to move
that might give you a more predictable time to open, if you need it.
Is spring tension adjustable, or maybe airgap in operated position? Those are what we tweaked back in days of telephone timing relays(early 60's).
I miss Pease Porridge. I got really excited when I saw the title "What's all this ...", so I was proud that I even came close to Bob's wisdom. Bob Pease was a very smart engineer. Emach you would do well to follow or at least understand his designs (first web link in meBigGuy's post).
First off, thanks everyone for the replies! I attached screenshots of the data plots illustrating my issue. Now down to business after reading the replies some additional information that would help flesh out the problem further:
1) You guys already hit on this but I will state it here for the record, we are using a spring return on the solenoid to return it to its initial de-energized state.
2) I am not kidding that our customer will want to PWM the solenoid when energized in order to save power. Our application is automotive and will see a wide range of temperatures, therefore ideally they will want to develop a temperature vs hold voltage profile in order to ensure it stays actuated but maximizes their power savings.
3) The diode I have in the test circuit is a RGP30GHE3/73 from Vishay. I am definitely open to a cheaper part that better meets my needs.
To run down the replies:
mjhilger & meBigGuy -
I meet with my customer tomorrow and can inquire if they will do PWM or not. If not I will definitely be looking at Bob's example you and meBigGuy pointed out.
meBigGuy - I found a reference to driving the coil with an H-bridge and the improved turn off performance that results from it. Thanks, I will definitely be breaking out the old breadboard and buying an H-bridge or two from Digikey.
jim hardy - the spring tension is not adjustable and there is no airgap in the actuated position.
Thanks again everyone.
Guys,
A follow up. Can anyone help with specifying the power rating or reverse current on the zener diode? I do not know the inductance of the solenoid but I do know the hold current and resistance of the coil.
I have not followed up to the extent you are headed, so I don't know all the info you need. But from a physics point of view there is an energy in the magnetic field that will be collapsing that needs to dissipate; coupled with that is the fact that some energy might be added back to the field as the solenoid releases and the energy of the force (K*X) [spring constant * distance] used to hold the plunger is added back in the field, or at least not used.
I think I would try and identify the solenoid that might be used and run some tests with a current and voltage probes in the flyback diode circuit maybe adding a small resistance 1 ohm or 0.5 ohm, to determine the energy released and consider a 50% safety margin or so and design from there.
Maybe you can just assume the current is linear starting at the holding current and ending at the time when it voltage collapses across the zener. Calculate the average I^2 and multiply by the zener voltage.
  • · Replies 42 ·
11K
  • · Replies 21 ·
11K
  • · Replies 21 ·
