Flyball governor and force on slider
  • Thread starter Thread starter Sdarcy
    Force Slider
The discussion revolves around the mechanics of a flyball governor, specifically focusing on the forces acting on a slider due to the rotation of the governor's balls. The problem involves calculating the force on the slider when the shaft rotates at a specified speed, with given parameters such as length, angle, mass, and rotational speed.
  • Participants explore the centripetal force acting on the balls and discuss how to resolve this force into components. There are inquiries about the methodology for splitting and recombining forces, as well as requests for guidance on drawing free body diagrams and calculating related parameters.
The discussion is ongoing, with participants seeking clarification on the force resolution process and the implications of the parameters involved. Some have provided mathematical expressions related to the forces, while others are looking for step-by-step guidance and additional context for similar problems.
Participants are working under the constraints of a homework assignment, which may include specific requirements such as drawing diagrams and calculating certain values. There is a mention of ignoring friction and the weights of components other than the balls, which may influence the approach to the problem.
Sdarcy
http://www.mech.uq.edu.au/courses/mech2210/yat/q/governor.jpg
A flyball governor is a device used to regulate the speed of steam turbines in steam power plants. The rotation of the shaft causes the two balls move outward. As the balls move out, they pull on the bearing A. The position of the slider A is linked to a valve admitting steam into the turbine. This way, the flow of speed is automatically restricted when the shaft starts rotating too fast.
The following data is given for the flyball governor shown in the figure:
L =300 mm
gama= 45 degrees
m = 1 kg (the mass of each ball)
N = 1452 RPM
What is the force (in N) pulling on the slider A if the shaft rotates at the speed given below? Ignore friction and the weights of the conmponents other than the two balls.
I have NO idea where to start with this one! Everything I do just seems to lead in circles and not get me anywhere...Any help would be much appreciated...
In the inertial coordinate system where the flywheel is at rest, there is a centripetal force acting on the balls:
[tex]F = m\omega^2 r = m \left(\frac{2\pi}{N}\right)^2 r[/tex]
which is directed radially away from the axis of rotation, and [tex]r[/tex] is the radius. Use trigonometry to split this force into components directed along the supporting beams and then combine them to find the net resulting force on the bearing. Don't forget to use SI units in your calculation.
I'm not sure how to split the force and recombine it. Do you mind stepping me through it?
Thanks
Let the tension along L be T. Then, projecting
[tex]2T\sin \gamma = F\, , \quad 2T = \frac{F}{\sin \gamma}[/tex]
The factor 2 is because there are two L's. Further, project the forces vertically to find the force on A:
[tex]F_A = 2T \cos \gamma = \frac{F}{\tan \gamma}[/tex]
HI, I found a similar qns and were asked to
a)draw the free body diagram of the ball and sliding collar
b)calculate y which is 2Lcos(gama) in this case, as a function of omega, that is the angular speed.
c)the min speed of rotation for th eball to "fly" (gama > 0)
anyone has any idea/clues on this qns?
thanks.
  • · Replies 18 ·
  • · Replies 56 ·
