How Does a Distorted Dewar Window Affect Its Focal Length?
AaronBurr
  1. What is the focal length of a dewar window distorted by a pressure difference? As a result of the pressure difference, the radius of the first surface of the window is R1 = 100 meters. The window is 3 mm thick, with an index n = 4 at l = 4 um.
I think I can just use the thin lens equation? 1/f=(n-1)/R
[/B]
My concern with using the thin lens equation is I'm not sure if a distorted window creates a lens? I know the focal length of a window is naturally infinite. If its bent does it then act as a lens? If not what formula do I use to prove it still acts as a window?Thanks for any help!
This is an excellent problem in that it teaches you practical applications. Basically, you still have a window if you are about 1/2 way, inside of the focal length. And that is, from a practical aspect, a window. However, crank out the numbers and you find that if you are far enough away (and with a good magnifying device, not sure what is applicable, Cause I didn't crunch the numbers either, maybe binoculars, maybe a large telescope), you will see an image, because it will behave like a lens past its focal point (at that distance, you may have trouble finding the focal point, hence the calculation).
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
