Loop Over Files in tcsh Shell - Command Line Tips
  • Thread starter ehrenfest
  • Tags
    Loop
In summary, it is possible to use a for loop at the command line in tcsh to loop over all files in a given directory and apply commands to each one. This can be done using the foreach command and can also be combined with the backtick operator or the find command.
ehrenfest
2,020
Is it possible to do a for loop at the command line over all files in a given directory using the tcsh shell? I want to loop over all files and apply some commands (e.g. sed) to each one.
EDIT: I called it a "for" loop because I saw a "for" command when I googled this problem but of course I just want to loop over all the files
Technology news on Phys.org
Yes. It's called foreach.
This will invoke the command 'do_something_to' on each .c file in the current directory:
Code:
foreach f (*.c)
   do_something_to $f
end
I often use foreach in conjunction with the backtick operator. This will invoke the command 'do_something_to' on every .c file anywhere in the directory tree headed by the current directory:
Code:
foreach f (`find . -name '*.c'`)
   do_something_to $f
end
The find command can of course do the above directly by using find's -exec option.
, not a specific list of values
Yes, it is possible to do a for loop at the command line over all files in a given directory using the tcsh shell. The syntax for a for loop in tcsh is slightly different than in other shells, but it is still possible to achieve the desired result. Here is an example of how you could loop over all files in a directory and apply a sed command to each one:
foreach file (`ls *.txt`)
sed -i 's/old_text/new_text/g' $file
end
In this example, the "foreach" command is used to create a loop that iterates over each file in the directory that ends in ".txt". The "ls" command is used to list all the files that match the pattern, and the backticks (`) are used to capture the output of the command and store it in the "file" variable. Then, the "sed" command is used to perform the desired text replacement on each file, using the "file" variable as the input. The "-i" flag is used to perform the replacement in-place, meaning it will overwrite the original file.
It is important to note that the "foreach" command in tcsh does not have the same functionality as a traditional "for" loop, as it does not allow for a specific list of values to be iterated over. Instead, it iterates over a set of values that are generated by a command, as shown in the example above.
In conclusion, it is possible to use a for loop in tcsh to iterate over all files in a given directory and perform commands on each one, such as using sed to make text replacements. However, the syntax and functionality may differ slightly from other shells, so it is important to consult the tcsh documentation for more information.
Related to Loop Over Files in tcsh Shell - Command Line Tips
1. How do I loop over multiple files in the tcsh shell?
To loop over multiple files in the tcsh shell, you can use the foreach loop command. For example, foreach file (*.txt) echo $file; end will loop through all files with the .txt extension and print their names.
2. How can I specify a specific file extension in the loop?
You can specify a specific file extension in the loop by using the wildcard * followed by the desired extension. For instance, foreach file (*.extension) command; end will loop through all files with the specified extension.
3. Can I use wildcards in my loop command?
Yes, you can use wildcards in your loop command to specify certain patterns or criteria for the files you want to loop over. Wildcards such as * and ? can be used to match multiple files or specific characters in a file name, respectively.
4. Is it possible to loop over files in subdirectories?
Yes, you can loop over files in subdirectories by using the foreach loop command with the ** wildcard. This will match all subdirectories and their files recursively. For example, foreach file (**/*.txt) command; end will loop through all .txt files in all subdirectories.
5. What is the difference between the "foreach" and "for" loop in tcsh?
The foreach loop is used specifically for looping over items in a list, while the for loop is used for iterating a certain number of times. In the tcsh shell, the foreach loop is preferred for looping over files and directories, while the for loop is more commonly used for numerical iterations.
