For which numbers is this convergence?
The discussion focuses on determining the convergence of an infinite geometric series defined by a=x/(x+1). The series converges when the absolute value of a is less than one, specifically for |a|<1. Participants suggest using the d'Alembert ratio test to analyze convergence. The key task is to find the range of x values for which this condition holds true. Understanding these parameters is essential for establishing the convergence of the series.
venke
Hi,
I need to know for which nubers of x the serie is convergence.
Is this possible whith d'Alombert? I have tried, but with no result.
Greets,
venke
Mathematics news on Phys.org
Your series is an infinite geometric series with a=x/(x+1). This series converges for |a|<1. You should be able to find what is the range of x for convergence.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
