How Long Does It Take for a Car to Stop with Friction After Engine Shutdown?
The discussion revolves around calculating the time it takes for a car to stop after the engine is turned off, given an initial acceleration and a frictional force. The car accelerates to a speed of 30 m/s after 15 seconds before the engine shuts down. The frictional force of 15N results in a deceleration of -0.015 m/s². The initial calculation mistakenly suggested an impractical stopping time of 2000 seconds. Participants emphasize the need for clarity in presenting the final time calculation.
Troubadour
If the engine of a car provides an acceleration of 2ms-2 to start it from rest, assuming the mass to be roughly 1000kg, calculate the time after which the car comes to rest if the engine is turned off after 15 seconds and the frictional force is 15N)
v=u + at
F= m*a
v= 0 + (2)(15) = 30ms-1
F= m*a = -15N= 1000 * a
Therefore, acc. caused by friction= (-15)/1000= -0.015
v=u+at, but car comes to rest, so v = 0
0= 30 +(-0.015)(t) = 2000sec
I'm not really sure of the answer as it seems to be quite impractical (:P).
Thanks.
~Troubadour
Looks like you did it right.
Other than writing
which is technically wrong since 0 != 2000sec. You should put t=2000s on a separate line
Other than writing
Oops...I didn't quite notice that...Thanks a lot for your help!
v=u + at
F= m*a
I'm not really sure of the answer as it seems to be quite impractical :)P).
Thanks.
~Troubadour
You missed the obvious solution. If you apply an accelerating force of 2000N for 15secs, how long do you have to apply a decelerating force of 15N to return to rest?
