Force Applied to Two Blocks: Which is Bigger?
  • Thread starter Thread starter thonwer
    Blocks Two blocks
9 replies · 2K views
thonwer
Two blocks with masses m1 and m2, m2>m1, are attached, I push from the left and from the right side, which force is bigger? The surface is frictionless.
http://imagizer.imageshack.us/v2/800x600q90/194/wkft.png
2. The attempt at a solution
I think it's bigger when applied from the left because of the reaction of m2 is bigger than the reaction of m1 because m2>m1, but I don't know any equations to corroborate it.
hi thonwer! welcome to pf! :smile:
i don't understand the question, there seems to be something missing :redface:
why can't the forces be whatever you want? :confused:
The force I have to consider is the arrow drawn in each case because it is what they ask me, the picture is part of the formulation.
What I mean on the question is, in one case I push from the left, in other case I push from the right. In which case the force is bigger so as to move the blocks?
hi thonwer! :smile:
but the picture shows the same letter, F, for both forces, which presumably means that they are equal :confused:
do you mean which acceleration is bigger?
Ok sorry, I did not explain myself quite well, the Force applied is the same in both cases.
The correct question would be, which reaction force is bigger?
I didn't understand you sorry, English is not my first language,
what did you want to say with "do good ol' Newton's second law for the block that the force F isn't on in each case" ?
sorry! :smile:
in the first picture, the force F is on the left, pushing on the smaller block
so do the equation "force = mass times acceleration" (ie Newton's second law) for the larger block
(and then do the same for the smaller block in the second picture)
For 1: F-R=m1*a -> R=F-m1*a
For 2: F-R=m2*a -> R=F-m2*a
F is the same, a is the same => m1*a<m2*a so R in 1 is bigger
Is it correct?
