Force between two long straight wires
  • Thread starter Thread starter nevsbrother
    Force Wires
The discussion focuses on calculating the electric field and force between two parallel charged wires. The electric field E generated by one wire at the location of the other is given as kQ/ld^2, while the total force F exerted by one wire on the other is calculated as kQ^2/ld^2 using F=qE. A specific case with a length of 1 m, distance of 1 mm, and charge of 1 µC yields a force of 9000 N, which is questioned as being excessively high. Participants emphasize the importance of showing detailed calculations to identify errors, noting that the units for the electric field calculation do not align correctly. Accurate calculations and unit consistency are crucial for resolving discrepancies in the results.
nevsbrother
Two long straight thin conducting wires run in parallel. The distance between them
is d and the length of each wire is l. One of the wires is charged with charge +Q, the
other wire with charge -Q
(a) Calculate the strength of the electric field E(Q; d; l) generated by one wire at the
location of the other wire.
(b) Calculate the total force F(Q; d; l) exerted by one wire on the other wire.
(c) What is F for a length of 1 m, a distance of 1 mm and a charge of 1 C?
for (a) I finished with... kQ/ld^2
for (b) I finished with... kQ^2/ld^2 using F=qE
for (c) I got an answer of 9000N which seems way too big.
I think I must have gone wrong somewhere
It doesn't really help to simply post the incorrect answers you got and then ask what went wrong. We can't tell without seeing your work. Show us what you did.
BTW, the units don't work out for (a), so your answer can't possibly be correct.
