Force between two uniformly charged identical rods
  • Thread starter Thread starter j0n
    Charged Force
The discussion focuses on calculating the force exerted by one uniformly charged rod on another identical rod, with both rods carrying charge +Q and separated by a distance b greater than their lengths. The electric field produced by the left rod at a point on the right rod is derived using integration, leading to the expression for the force. The correct limits for integration are emphasized, specifically from b-a to b+a, to accurately compute the force. The final expression for the force is given as F = (k Q^2)/(4a^2) ln(b^2/(b^2 - 4a^2)). The discussion highlights the importance of careful integration and maintaining constants throughout the calculations.
j0n
Identical thin rods of length 2a carry equal charges, +Q, uniformly distributed along their lengths. The rods lie along the x-axis with their centers separated by a distance b > 2a. Find the force, F, exerted by the left rod on the right one.
Left rod's center @ (0,0) → rod stretches from (-a,0) to (a,0)
Right rod's center @ (b,0) → rod stretches from (b-a, 0) to (b+a, 0)
They give that
F = \frac{k Q^2}{4 a^2} \ln \frac{b^2}{b^2 -4a^2}
Also we know that λ = \frac{Q}{2a} = \frac{dQ}{dx} , \space and \space Q = Q_1 = Q_2
Electric field produced by rod 1 at a point x > 2a:
E_1(x) = \int \frac{k}{χ^2}dQ = \int_{x-a}^{x+a} \frac{k}{χ^2} λ dχ = \int_{x-a}^{x+a} \frac{k}{χ^2} \frac{Q_1}{2a} dχ = \frac{k Q_1}{2a} \int_{x-a}^{x+a} \frac{dχ}{χ^2}
= \frac{k Q_1}{x^2 - a^2}
Now I understand that FTOT = Ʃ qiE1(xi),
where qi are the infinitesimal contributions of Q2 (= Q).
So shouldn't I have F = \int_{x-a}^{x+a} E_1(χ) λ dχ ?
If so then I have:
F = \int_{x-a}^{x+a} \frac{k Q_1}{χ^2 - a^2} \frac{Q_2}{2a} dχ
= \frac{k Q^2}{2a}\int_{x-a}^{x+a} \frac {dχ}{χ^2 - a^2}
And I'm stuck.
By the way I used chi (χ) as a dummy variable when integrating since I wanted to obtain E as a function of position along the x-axis.
Thus, E_1(x= b) = \frac{k Q_1}{b^2-a^2}
Edit:
I think I might've solve it now. Instead of cancelling 2a out when I calculated E1(x), I just left it.
So then E_1(x) = \frac{k Q_1}{2a} (\frac{1}{x-a} - \frac{1}{x+a})
Then in finding the Force on rod 2 my range of integration should specifically be from b-a to b+a (not x-a to x+a).
So, F = \frac{k Q^2}{4a^2}\int_{b-a}^{b+a} (\frac{1}{χ-a} - \frac{1}{χ+a}) dχ
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
