Force due to three magnetic fields
The discussion focuses on calculating the magnetic field at a specific point near a wire configuration shaped like three sides of a square. The initial approach suggested using Ampere's Law, but participants noted that it may not be suitable due to the lack of cylindrical symmetry in this case. Instead, the Biot-Savart Law is recommended for deriving the magnetic field, with an emphasis on integrating over the wire segments. The problem may involve symmetry that could simplify the calculations, potentially reducing the number of integrals needed. Ultimately, the correct method involves careful consideration of the wire's geometry and the application of the appropriate magnetic field laws.
Frostfire
A wire comes in from in finity (left side) and forms a shape by going up a length A, over a length A and back down a length A.(forming three sides of a square that is attached to this infinite wire), then
takes a turn and leaves the page opposite to the side it came in on, headed to infinity.
There is a particle along the horizontal axis of this, a length 1/2 A from the left or right side of the shape, what is the magnetic field at that point,
the answer is (sqrt 5)/5 * (Mu * I)/pi A But I have no idea how to get there
Try Ampere's Law. \oint \vec{B} \cdot d\vec{l}=\mu_{0}I_{enclosed}
Would this qualify as high sym.?
The way I was going to approach it was calculate the force on the particle due to the two verticle lengths of wires, since it would just be the force due to 1*2, then add the effect of the upper horizontal wire to that. But how do you calculate the first part? Can I use Ampere's law ?
Superpose the fields from each of the sides of interest. The wire has cylindrical symmetry so you can use Ampere's law.
Actually, Ampere's Law is not going to help with this one. Only infinitely long, straight wires have the appropriate cylindrical symmetry.
But you can solve this by using Biot–Savart law, and integrating over the length of each straight-line segment. There is some symmetry involved, so you might not have to integrate over every segment. But you'll probably need to break up the problem into at least two integrals (3 integrals if you ignore the symmetry).
