Force exerted by water in a U-shaped tube
  • Thread starter Thread starter Dansuer
    Force Tube Water
In a U-shaped tube with water flowing at a constant velocity v and flow rate u, the force exerted by the water on the wall is derived from the change in momentum. The calculation shows that the change in momentum is 2uvΔt, leading to the conclusion that the force F equals 2uv. This solution is confirmed as correct by participants in the discussion. The interaction highlights the relationship between flow rate, velocity, and the resulting force on the tube walls. Understanding these principles is essential for analyzing fluid dynamics in similar systems.
Dansuer
In a U-shaped tube, water is flowing with velocity v. The flowing rate is u, and it's constant. What force does the water exert on the wall of the tube.
F = dp/dt
u = m/t
The change in momentum is
mv - (-mv)
or
2uv \Delta t
so
F = 2uv
is this correct?
Yes, that's correct.
Thanks a lot !:biggrin:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
