Can Velocity be Determined from Force as a Function of Angle in Mechanics?
The discussion centers on determining the velocity of a particle moving in a vertical circle when a force acts on it as a function of angle. The force is given by F=(Mmg(1+cosα))/(M+m), where M and m are masses with M greater than m. It is noted that while determining velocity from a time-dependent force is straightforward, the challenge arises when the force is expressed as a function of angle. However, it is suggested that knowing F(α) allows for the calculation of potential energy, which can then be used to find velocity through energy conservation principles. This approach provides a viable method to analyze the motion of the particle in the given scenario.
Gloyn
Hello!
I've been doing some excercises in mechanics and stopped for a moment over the thing that sometimes bothers me. I have a set of particles of masses M and m, M>m. If I have force acting on m particle as a function of angle:
F=(Mmg(1+cos\alpha))/(M+m)
(m is moving in on the surface of a verticle circle of radius R, powered by the falling M particle, both particles are connected by a string)
is there a way to determine the velocity of particle in a point described by coordinates (\alpha;R)? If force was in funtction of time, that would be obvious, but what about the function of the coordinate?
Hmm, your force looks strange. However, if you know F(alpha), you can determine a potential and get v(alpha) via energy conservation.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
