Force induced on a point charge by two conducting planes
In summary, the conversation involves finding the force acting on a point charge located near two grounded conducting planes intersecting at right angles. The participants discuss how much charge would be induced on the planes, the potential on the planes, and how to maintain such a condition. The solution involves creating an equivalent charge system and using the formula F = k[(q1*q2)/r^2] to find the force of each charge on the initial charge, and then adding them together. There is some discrepancy in the final result between the participants, with one suggesting a factor of (1/4) and the other getting different values for the x component of the force.
Strawberry
A point charge q is located in the xy plane near two grounded conducting planes intersecting at right angles as shown in the Figure. The z axis lies along the line of intersection of the planes. Find and justify (mathematically show) the force acting on this charge q (both direction and magnitude should be specified).
1. Think about how much charge would be induced on the conducting planes.
2. What would be the potential on the conducting planes (This is the boundary condition) and what can you do to maintain such a condition?
3. If a different method was used for your calculation, please describe the method.
A .doc file containing the question and a diagram is attached.
I'm assuming a negative charge is induced on the conducting planes, but beyond that I seriously have no clue. Absolutely any help whatsoever would be greatly appreciated.
I found a website with a related problem by google searching "force point charge conducting plane." It's the davidpace one ( I can't link to websites yet). Can I do basically the same thing with each conducting plane individually and use vector addition to find the resultant force?
  • Homework 6 Problem.doc
Okay, after looking this over more, I'm thinking that replacing the conducting plates with three point charges would make an equivalent system. Using the plates as axes, there would be mirrored negative charges across the x, y, and y= -x axes. So charges like a square, with one corner being an opposite charge. After that, the force calculation would just be a system of point charges. Is this the right idea?
Hi strawberry,
That is the right idea; however I believe you need two corners to be oppositely charged that of the original point charge. Do you see why? Which two corners would you choose?
Thank you very much for your response alphysicist. I took your advice and I think I have the right answer.
The equivalent charge system is like a square with opposite corners having the same charge, I think.
(-q) - - - q
q - - - -(-q)
Taking V to be the sum of V for each charge at the origin, (0,a) and (a,0) I found V to be 0 along the original conducting plates. After that I used F = k [(q1*q2)/r^2] r to find the force of each equivalent charge on the initial charge. I ended up with three forces, then added them together.
My final result was F = k* (q^2 / a^2) * [ sqrt(2) - 4 ]/4 * i + [ sqrt(2)-4)/4 ] * j ]
Hi Strawberry,
It looks to me like you are missing a factor of (1/4). Am I just reading your final result wrong?
Well I have everything divided by 4, should it be divided by 16?
Is this more clear?
F = k* (q^2 / a^2)/4 * [ sqrt(2) - 4 ] * i + [ sqrt(2)-4) ] * j ]
I'm getting something different from that. For example, for the x direction, I am getting
[tex]
F = \frac{k q^2}{(2a)^2}
[/tex]
for the particle at the upper left corner, and
[tex]
F = \frac{kq^2}{(\sqrt{2}\cdot 2a)^2} \cos(45^{\circ})
[/tex]
for the x component from the particle at the lower left corner. I then subtract those. Is that what you got? I don't think that gives the answer for the x component that you stated. Or am I thinking of it wrongly?
What is the definition of force induced on a point charge by two conducting planes?
The force induced on a point charge by two conducting planes refers to the force exerted on a charged particle when it is placed between two parallel conducting plates. This force is a result of the interaction between the electric fields produced by the two plates and the charge of the particle.
How is the force induced on a point charge by two conducting planes calculated?
The force induced on a point charge by two conducting planes can be calculated using Coulomb's law, which states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them. In this case, the two charges are the two plates and the point charge, and the distance between them is the distance from the point charge to the plates.
What factors affect the force induced on a point charge by two conducting planes?
The force induced on a point charge by two conducting planes is affected by several factors, including the magnitude of the charges on the plates and the point charge, the distance between the point charge and the plates, and the dielectric constant of the material between the plates.
What is the direction of the force induced on a point charge by two conducting planes?
The force induced on a point charge by two conducting planes is always perpendicular to the plane of the plates and parallel to the direction of the electric field between them. If the two plates have opposite charges, the force will be directed towards the positively charged plate. If the two plates have the same charge, the force will be directed away from them.
How can the force induced on a point charge by two conducting planes be manipulated?
The force induced on a point charge by two conducting planes can be manipulated by changing the distance between the plates, altering the charge on the plates or the point charge, or by changing the material between the plates. Additionally, the direction of the force can be changed by reversing the charges on the plates or by changing the orientation of the plates.
