Force on a magnet inside a short coil
The discussion centers on understanding how the force on a magnet changes with distance from a coil, particularly noting that the force acts in opposite directions when the magnet is above or below the coil, suggesting a zero crossing point at the coil's center. The assumption that the force versus displacement graph will reflect this behavior is considered reasonable. Additionally, the conversation explores the creation of a hollow core magnet by drilling a cylindrical piece of iron and applying a strong magnetic field, which aligns the magnetic domains. It is noted that there would be no significant qualitative difference in force behavior between solid and hollow core magnets, although the distribution of magnetic poles may affect the actual force experienced. Overall, the principles of magnetism and coil interaction are highlighted, emphasizing the complexity of the equations involved.
CraigH
The equations are incredibly difficult, so I'm just after a general idea of how the force on a magnet bellow a coil changes with the distance to the coil. Shown bellow:
Code:
Axial symmetry:
o                 x
o                 x               cross section of coil
o                 x
o                 x
         x                      displacement (x)
         _
        |_|                       cylindrical bar magnet
From intuition, I would say that the force on the magnet is acting in opposite directions when the magnet is above or bellow the coil. So there must be a zero crossing point. It makes sense that this will be in the center of the coil. So in this case the force vs displacement will look something like this, assuming that x=0 is when when the magnet is in the center of the coil. Is this an okay assumption?
How would things change if the magnet had a hollow core: like bellow?
Code:
Axial symmetry:
o                 x
o                 x
o                 x
    _         _
   |_|       |_|                  cross section of hollow core magnet
How would you create a "hollow core" magnet?
Find a cylindrical piece of iron (or other material that retains a magnetic field), drill a whole through it (like this), and then apply a strong external magnetic field. The magnetic domains in the material should align creating a magnetic annular prism (i.e a hollow core magnet)
There would be no qualitative difference between the two situations. the actual force if the pole strengths remained the same may vary somewhat due to the different distribution of the magnetic poles and their position in the relatively inhomogeneous field of the solenoid.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
