Force on rigid body: translation or rotational acceleration?
A perpendicular force applied to the tip of a thin rod generates both translational and rotational acceleration, while a force at the center results in only linear acceleration. The validity of Newton's Second Law (NSL) for linear acceleration is questioned when the force does not act on the center of mass. It is clarified that while NSL applies, additional considerations for torque and rotational dynamics must be made. The discussion emphasizes that the force applied at different points results in the same work when considered over the same short time interval, but the rotational motion requires more distance for the same force. Understanding these dynamics helps clarify how forces affect extended objects like rods.
lordsurya08
A perpendicular force F acts on the tip of a thin rod of length L and mass M in the ij-plane which is not fixed. What is the translational and rotational acceleration of the rod about the center of the rod?
At first it seems like an easy problem.
a-linear = F/m (NSL, system : the rod)
t == r X F == rFsin 90 k == rF k
so a-rot == t/I == rf/I k
The equations are easy to solve but that's not what I'm having trouble with. I don't know if NSL for linear acceleration is valid if the force doesn't act on the Center of Mass.
If it is valid, that means that if F acted on the center, there would be only linear acceleration, but if F acted on the tip, there would be the same linear acceleration in addition to rotational acceleration.
Thus the force, if applied for a short distance, does more work when it is on the tip then when it is on the center. This is unintuitive.
Newtons second law doesn't apply easily to extended objects. If you are exerting a force on the end of a rod, the rest of the rod is also exerting a force on the end of the rod you are pulling to accelerate along with the end you are pulling. That's Newton's third law. You would have to account for all of these forces. Does that make it seem a little more intuitive why NSL doesn't directly apply?
Thanks for the reply.
1. Can I still use NSL for the rotation about the center of mass? (i.e. t = Ia)
2. Can I pick a random reference point, find the torque of the force about that point, get angular acceleration about that point, and use [a-trans = a-rot * r] to get the linear acceleration?
Newton's Second Law holds.
Fexternal = M aCM.
Fexternal = M aCM.
SammyS is right, of course. I managed to confuse myself. The force applied to two different points for the same distance does the same work. Better to think of the force applied to the two different point for the same short time. The final CM velocity will be the same but the force applied at the end will need to be applied over a larger distance. That's where the extra work for the rotational motion comes from.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
