Force on solenoid in external uniform field?
The discussion centers on the behavior of a solenoid placed within a uniform magnetic field, specifically regarding the torque exerted on the solenoid and the interaction between the solenoid's internal magnetic field and the external field. Participants explore theoretical implications, potential forces, and the nature of magnetic interactions in this context.
  • One participant questions whether a torque will be exerted on the solenoid, considering the orientation of the external magnetic field relative to the solenoid's magnetic field.
  • Another participant suggests that the torque on the solenoid would be similar to that on a permanent magnet, proportional to the cross product of the solenoid's axis vector and the external magnetic field vector.
  • A different viewpoint indicates that the external field interacts with the solenoid's internal field, which is in the opposite direction, potentially affecting the overall interaction.
  • One participant asserts that the external magnetic field acts only on the current flowing through the solenoid, leading to effects similar to those of a permanent magnet.
  • Another participant elaborates that each turn of the solenoid behaves like a plane coil, experiencing a torque due to the external field, while also noting a small force due to the current along the solenoid's axis.
  • A later reply introduces a complex perspective, discussing the visualization of magnetic fields and their interactions, suggesting that the external field may not interact with the flowing charges in the solenoid as initially assumed.
Participants express differing views on the nature of the interaction between the solenoid and the external magnetic field, with no consensus reached on whether the external field exerts a torque or force on the solenoid. Multiple competing interpretations of the magnetic interactions remain present throughout the discussion.
Participants reference historical experiments and models, indicating that the discussion may involve assumptions about the nature of magnetic fields and their interactions that are not fully resolved. The complexity of the solenoid's geometry and the behavior of current within it are also noted as factors that could influence the outcomes discussed.
neosocra
A solenoid, of sufficient length to consider external flux to be zero, passes through a uniform magnetic field with significant length on both ends extending beyond the field.
Will a torque be exerted upon the solenoid ? Or do the windings effectively mask the internal solenoid field from the external? (again, with each solenoid pole well beyond the field; a very long permanent magnet would receive a torque, I'd imagine)
Would the vector orientation of the external uniform field relative to the B vector of the solenoid make any difference?
There would be the same torque as on a permanent magnet proportional
kXB (k is a vector along the axis of the solenoid.).
Since the external field of the solenoid is in opposite direction than the internal concentrated flux, I could see that field interfacing with the uniform external field, but with an opposite B vector. Is that what you mean?
The external uniform magnetic field acts ONLY on the current in the solenoid.
The result, though, is the same as if the solenoid were replaced by a permanent magnet.
Magnetic fields don't create force on other fields.
Each turn in the solenoid is almost a plane coil in itself, and experiences a pure couple in an external field. The couples on all the turns add together. The fact that the turns are staggered apart in space makes no difference to the addition.
There is, in fact a small BILsin(theta) force on the solenoid because there is a flow of current parallel to the solenoid axis, owing to the helical nature of the solenoid. [When Ampere was doing his pioneering experiments in the 1820s, and trying to make a pivoted solenoid behave like a magnet, he was at pains to neutralise this parallel-to-axis current with one in a wire running the other way.]
I simultaneously agree, and say "wait but..." to myself. Think about the classic method of visualizing the orbital magnetic field from a straight conductor and how that field creates flux density changes as the FIELDS intersect (or more accurately, Don't intersect) causing attraction on the point in the orbit parallel to the uniform field and repulsion when opposite (same analogy as parallel wires of same or opposite direction) *image attached*
I'm well aware that this is done as a tool to visualize effect and not the true cause of force that does come down to point charges in the conductor moving in the current. However, think of the Gilbert model for closely estimating forces between two magnets as point charges on the pole faces. Now we've modeled electrical charges in conductor as magnetic field / magnetic field interaction, and yet magnets as pretend electrical charges. However, in permanent magnet there is no moving point charge, only magnetic fields...
So it'd seem that the fact that no flux is measured outside a (long) solenoid then the effect from that current, add more specifically the charges its comprised of, is redirected by influence of neighboring loops, and thus my hypothesis of the uniform external field passing through a section would likewise not interact with those flowing charges, no matter how you model it... I'm also, like I lead off, expecting I'm wrong, I'm just not Yet reading an invalidation of my false (?) assumptions
10K
