Force Per Length and Magnitude of a Current
A long cylindrical wire carrying a current of 100A creates an attractive force of 0.25 N/m on a second parallel wire located 7 mm away. The initial calculation for the current in the second wire was incorrectly derived, resulting in an answer of 8750A. Upon realizing the mistake and using the correct formula, the current I2 was recalculated to be 87.5A. The discussion highlights the importance of using the right equations in electromagnetic force problems. The participant expresses hope that their experience helps others avoid similar errors.
hexus0
1.A long, thick (cylindrical, solid) wire of radius 3 mm carries a total current of I1 = 100A that is uniformly distributed over its cross-sectional area. The current is in the +z direction. A second, thin wire runs parallel to the axis of the thick wire and is located at a distance of 7 mm from the center of the thick wire (see the figure). Initially there is no current flowing in the second wire (i.e., initially I2 = 0).
A current I2 (of unknown magnitude and direction) is now switched on in the second wire. The resulting force per-unit-length exerted on the second wire is measured to have a magnitude of 0.25 N/m, and the wires feel attractive forces. What is the magnitude and direction of the current I2?
F = ILxB
B = u0I/(2*pi*r)
Using F/L = 0.25 N/m, I set that equal to u0I/(2*pi*r)
so
(F/L) = u0I/(2*pi*r)
Solving for I:
I = [(F/L)*(2*pi*r)]/u0
Plugging in the values gave me I = 8750A. My professor has provided the answers for this study guide and the answer is 87.5A. I realized I made this same mistake on my exam and I was also off by 2 decimal places. I also posted this on my professor's forum, but no answer yet (posted earlier this morning). Any help is appreciated!
Thank you!
Figured out my problem, I was using the wrong equation.
F/L = u0*I1*I2/(2*pi*r)
Solving gives:
I = (F/L)*2*pi*r/(u0*I1)
I = 87.5A
Hope I didn't waste anyone's time and hopefully someone can learn from my mistakes!
