Resolving Forces on an Inclined Plane: Finding the Components of a Force
The discussion revolves around resolving a downward force acting on an object on a 45-degree inclined plane into its components parallel and perpendicular to the plane. Participants are exploring the mathematical representation of these components and the underlying principles of vector resolution.
  • Participants are attempting to express the force vector in terms of its components along the inclined plane. There are discussions about using trigonometric functions and vector projections, with some questioning the correctness of their chosen vectors and the application of the dot product.
The conversation is ongoing, with various participants providing insights and corrections. Some have suggested specific vectors for parallel and perpendicular components, while others are working through the projection formula and its application to the problem. There is a mix of understanding and confusion regarding the resolution process.
Participants are facing challenges with the representation of vectors and the application of mathematical formulas, including issues with LaTeX formatting. There is also a reference to a textbook answer that may not align with the current calculations being discussed.
jonroberts74
Suppose a force F is acting downwards on an object sitting on a plane that is inclined 45 degrees to horizontal. express the force as a sum of a force acting parallel to the plane and on acting perpendicular to the plane
I figured I need to use ||F||cos 45i+ ||F||sin 45j
and the angle between the plane and x-axis will the be the same angle between the downward and perpendicular
this is where I am getting stuck
You need a picture and a coordinate system. For example if your force is pointing straight down you would have ##\vec F = -\|\vec F\|j##. In your drawing what do you get for the vectors parallel and perpendicular to the plane. You need those next.
if \vec{F} = -||F||j
then \vec{F} dotted with <1,0> would be zero
the angle between <1,0> and the vector parallel to the plane wouldn't that be cos \theta = \frac{\vec{a}*&lt;1,0&gt;}{||a|| ||&lt;1,0&gt;||} where vector a is the parallel to the plane
I don't know if I am getting closer
sorry, it the wrong slash key, I am entering it in properly but it's not working
Please edit your post using [/tex] brackets to end your tex to make it readable and preview it before posting.
I used the correct brackets and it still is not working
jonroberts74 said:
if ##\vec{F} = -||F||j##, then ##\vec{F}## dotted with ##<1,0>## would be zero. The angle between ##<1,0>## and the vector parallel to the plane wouldn't that be $$cos \theta = \frac{\vec{a}*<1,0>}{||a|| ||<1,0>||} $$ where vector a is the parallel to the plane
I fixed your tex in my quote above.
Anyway the vector <1,0> doesn't have anything to do with this. What I asked you to do in my first reply was to give two vectors, one down the plane and one perpendicular to it. You should be able to do that from your picture. Don't give me unknown vectors ##a## or sines and cosines. Give me explicit vectors with numbers. While you are at it make them unit vectors. The rest will be easy after that.
<1,1> would be one parallel to the plane and <1,-1> would be perpendicular to the plane
\vec{F} = &lt;1,1&gt; + &lt;1,-1&gt;
No, that isn't how you resolve F.
I think you want <-1,-1> parallel but headed downward. Make them unit vectors and call the unit vectors ##p## and ##n## for parallel and normal.
Now remember that the scalar component of a vector ##a## in the direction of a unit vector ##\hat d## is given by ##a\cdot \hat d## and the vector projection in that direction is ##(a\cdot \hat d)\hat d##. Use that formula to get your resolution of F.
I will be gone from this thread until tomorrow sometime.
I don't know anything about resolving forces.
&lt;1,1&gt;-&lt;1,-1&gt;=&lt;0,2&gt;
would be be a sum of the parallel and perpendicular resulting in the downward force
I know the projection formula \vec{p} = \frac{\vec{a}*\vec{v}}{||a||^2}\vec{a}
\vec{p} = &lt;\frac{1}{\sqrt{2}}, \frac{1}{\sqrt{2}}&gt; ; \vec{n} = &lt;\frac{1}{\sqrt{2}}, \frac{-1}{\sqrt{2}}&gt;
I didn't do <-1,-1> because that seems perpendicular to the plane and not parallel
See the attached figure. In a coordinate system with vertical (y) and horizontal (x) directions then the vector F can be described by ##\vec F = F \hat{y}## since it is pointing down and there is no horizontal component.
Your job is to rewrite the same vector F in a new coordinate system defined with axes parallel and perpendicular to the plane, denoted by the bold lines in the sketch. Convince yourself that angle x is also 45 degrees. Then, to find the projections of F onto the directions parallel and perpendicular to the plane, it boils down to finding the 'adjacent' and 'opposite' sides of the triangle I have shown. Can you find these?
That is the same as the formula I gave where ##\frac {\vec a}{\|\vec a\|} = \hat a##
If <1,1> is parallel to the plane then so is <-1,-1>. You want whichever is in the right direction to fit your picture. You need to use your projection formula on the parallel and perpendicular vectors to get the two forces you want. Your ##\vec v## is your given force vector and the ##a## in your formula is either your ##\vec p## or ##\vec n## vectors.
<-1,-1> would be the given for the parallel
I did the projection for that and the parallel (I had it all typed out but couldn't get the latex to work on this website, never have trouble with it anywhere else)
getting
&lt;\frac{-1}{2}, \frac{-1}{2}&gt;
this seems to be getting overly complicated.
or is v the initial downward force which would be -j
I checked the book, it gives the answer as
\vec{F} = (||F||v+||F||h)/\sqrt{2}
where v=(i-j)/\sqrt{2} and h=-(i+j)/\sqrt{2}
I've attached a diagram, which is something I hope you have drawn for yourself. The normal unit vector ##\hat{n}## points in the opposite direction than yours. (I was too lazy to fix the picture, but it doesn't make a difference anyway.) I'm assuming the positive direction for the x' axis is up and to the right, and for the y' axis, up and to the left.
##\vec{A}## and ##\vec{B}## are the components of ##\vec{F}## along the rotated axes. You can see that both components point in the negative direction on their respective axes.
According to the projection formula, you have
$$\vec{A} = (\vec{F}\cdot\hat{p})\hat{p} = \left(\langle 0,-F \rangle \cdot \left\langle \frac{1}{\sqrt{2}},\frac{1}{\sqrt{2}}\right\rangle\right) \hat{p}.$$ What do you get when you work that out?
Do the same thing using ##\hat{n}## to find the normal component, ##\vec{B}##.
so
&lt;0,-F/\sqrt{2}&gt;\hat{p}
&lt;0, \frac{-F}{2\sqrt{2}}&gt;
that doesn't seem related to the answer the book gives
No. You need to look up how to calculate a dot product.
&lt;\frac{-F}{2},\frac{-F}{2}&gt;
\hat{p} = &lt;\frac{1}{\sqrt{2}}, \frac{1}{\sqrt{2}}&gt; this is what I had for \hat{p} before
I know how to do the dot product, I had a lapse in what was going on there. this doesn't seem any closer to the answer
What is this supposed to be? ##\vec{A}##?
Once you put the minus signs in your ##\vec p##, don't the ##v## and ##h## in the book's answer look a lot like they have used your ##\vec n## and ##\vec p## in the calculation? You are getting close.
&lt;\frac{-1||F||}{\sqrt{2}}, \frac{-1||F||}{\sqrt{2}}&gt; + &lt;\frac{||F||}{\sqrt{2}, \frac{-1||F||}{\sqrt{2}}&gt;
I can't get this to come up properly, it has proper tags, not sure why it won't show up properly
yes
I did the dot then the product of that by p hat
OK, so you have that the parallel component of ##\vec{F}## is
$$\vec{A} = -\frac F2 \hat{i} -\frac F2 \hat{j} = -\frac{F}{\sqrt{2}} \hat p.$$ Doesn't that match what's shown in the picture? Isn't it the same as what the book says is ##\frac{\|F\|}{\sqrt{2}}\hat{h}##?
jonroberts74 said:
&lt;\frac{-1||F||}{\sqrt{2}}, \frac{-1||F||}{\sqrt{2}}&gt; + &lt;\frac{||F||}{\sqrt{2}}, \frac{-1||F||}{\sqrt{2}}&gt;
You were missing a closing }.
ah I see, physics is not my strength
\frac{F}{\sqrt{2}}\hat{n} - \frac{F}{\sqrt{2}}\hat{p}
this leads into another question I have then, its similar so I don't see a point in making a new thread for it
2) an object is moving in the direction i + j is being acted upon by the force vector 2i + j, express this force as the sum of a force in the direction of motion and a force perpendicular to the direction of motion.
so do the projection of f onto i+j and projection of f onto i-j
\vec{F} = &lt;\frac{3}{2}\hat{i} + \frac{3}{2}\hat{j}&gt; + &lt; \frac{1}{2}\hat{i} - \frac{1}{2}\hat{j}&gt;
You should make a new thread!
It's in the rules for this Forum.
Not only that, but you should also show your steps instead of just giving an answer and expecting us to work the whole thing ourselves to see if your answer is correct.
