Archived Forces in achilles and foot bone
  • Thread starter Thread starter tristanmagnum
    Forces
The discussion focuses on calculating the forces acting on the Achilles tendon and foot bone when a person elevates on the ball of one foot. The tension in the Achilles tendon (FT) and the downward force exerted by the lower leg bone (FB) need to be determined using force and moment equilibrium equations. Participants note that the moment equation provided is incorrect, which complicates the solution process. A suggestion is made to model the foot as a cantilever beam to better analyze the forces. Correct application of the right-hand rule is also emphasized for accurate calculations.
tristanmagnum
The Achilles tendon is attached to the rear of the foot as shown in (Figure 1) . A person elevates himself just barely off the floor on the "ball of one foot." Assume the person has a mass of 80kg and D is twice as long as d.
a:Find the tension FT in the Achilles tendon (pulling upward).
b:Find the (downward) force FB exerted by the lower leg bone on the foot.
http://session.masteringphysics.com/problemAsset/1706786/4/GIANCOLI.ch09.p34.jpg
FB + FT -m*g = 0 [Force Equilibrium]
FB*D + FT*(D+d) = 0 [Moment Equilibrium]
i think
not sure what to do because there doesn't seem to be enough info.
Model the foot as a beam with the end opposite of the tendon as a cantilever. There is plenty of info to solve the problem. Unfortunately your moment equation is incorrect which is causing problems. And remember to use the right hand rule.
