Forces on an underwater vessel
The discussion focuses on calculating the stress that a 16" diameter, 8" high fiberglass hemisphere can withstand underwater. The vessel is described as having a closed top, resembling an upside-down bucket. Water pressure will compress the air inside, but the pressure inside and outside will generally equalize, preventing catastrophic failure. Concerns are raised about the pressure differential, particularly if the vessel's height leads to significant differences in pressure from top to bottom. Overall, the vessel is unlikely to fail unless there is a substantial imbalance in pressure.
yellowcouch
I have a question about a Fiberglass Hemisphere that is 16" in diameter and 8 " in height. It is being used as a vessel under the water so it has a closed top. I wanted to know how to figure out how much stress from water pressure it will handle before it fails.
thanks!
Which way up is it? Are you saying it has a flat top, or a (possibly open) flat base?
I understand it this way that you have a kind of bucket upside down. The water pressure will compress the air inside, at the same time as the surrounding pressure (outside the vessel) is the same. The vessel will be filled with water as the air is compressed to a smaller volume. The vessel will probably not "blow apart" under such experiment unless the vessel is so tall that there is considerably less water pressure at the top compared to the bottom. The air inside will have approx the same pressure acting on the walls any place inside. Considerably higher on the top compared to the water pressure outside - too much difference and it will blow apart.
Vidar
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
