Formula to assess wear due to friction in sheaves/pulleys
  • Thread starter Thread starter Antonius Robertus
    Formula Friction
Estimating wear due to friction in pulleys involves understanding material combinations and conducting tests, as existing formulas like the capstan and Archard equations may not provide direct links. Practical design focuses on selecting materials and conditions that minimize wear, supported by empirical data from experiments. Resources such as handbooks can offer wear rate formulas, but they cannot replace solid test results. Additionally, the traction force on a winch rope is influenced by the number of spools on the drum, necessitating a minimum contact area to prevent sliding. Determining the required length of spooled rope for a specific traction force remains a key inquiry.
Antonius Robertus
Hi everyone and greetings from a new member.
I'm looking for informations about how to estimate the wear due to friction of a rope as it passes through a pulley. Couldn't find anything really consistent about the subject. I looked at the capstan and Archard equations but didn't manage to link one to the other.
Does anyone have any ideas ?
Thanks a lot
A. R.
Search on ' tribology friction wear ' .
To solve actual problems of wear rate you generally need data from previous experience or lab tests or from tests on a prototype of the device being worked on .
There are handbooks which give wear rate formulas and a selection of wear data for common material combinations but they are no substitute for solid data from tests .
At least one high tech company I know of conducted extensive experiments to determine wear characteristics of many materials running against each other under a range of loading and lubrication conditions .
Generally most effort in practical design goes on selecting known material combinations and running conditions that will minimise wear during service life .
Hi Nidum, thanks for your answer !
I search on tribology and found some interesting stuff. But as you said, it depends a lot on material combinations and tests results. Anyway, thanks for your help.
Now here's another question, not directly linked to friction wear on pulleys. Does the traction force on a winch rope depend on how many times the rope is spooled on the winch drum ? In other terms, is it necessary to have a minimum length (or minimum contact area) of rope spooled on the drum to avoid sliding ? If so, I would like to know how to determine this required length of spooled rope to get a given traction force.
Thanks
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
10K
12K
