Formulas For Engine Cylinder Perssure
60 replies · 12K views
Is your piston acceleration and velocity relative to crank angle shown as being sinusoidal on that graph?
Piston Displacement = √((con rod length)*2 + (crank radius)*2 - 2lrcos(con rod angle))
Hi guys, I have been doing updates to the spreadsheet all day, so I remember very little about the specs of that engine. However, if its piston position, velocity, and acceleration you want to look at, here are a few graphs all for the same engine. all data logged on the graphs are taken at 3000 Revolutions Per Minute.
Engine: TOYOTA 2JZ-GTE
Specifications
Engine Type: Inline Six Cylinder Engine
Valve-train: DOHC w/wo VVT-i
Aspiration: Sequential Twin Turbochargers
Bore: 86 mm
Stroke: 86 mm
Connecting Rod Length: 135mm-145mm (145mm used in graphs)
Compression Ratio: 8.5:1
*Note: If the graphs do not display all of the cylinders in the engine, it is probably because they are at the same position/velocity/acceleration as the one/all of the cylinders.
Ex: Inline Six
720÷6=120
120*3=360, Cylinder Four is at the same position as Cylinder One, Because it's crank angle is spaced one revolution after cylinder one. I don't know how to solve this
Why do you need to solve it? Two pistons will have the same inertia component. They will be be different when you include the cylinder pressure information as they will be on different strokes.
Cylinder 4 wouldn't be the same as cylinder 1 though in an I6. Look at an animation of an I6, the cylinders should be phased according to firing order. 153624.
Cyl1=Cyl6
Cyl2=Cyl5
Cyl3=Cyl4
does anyone know what unit of measure would the bottom equation be in?
((P–Patm)*A*r)÷(sin(a+p))/cos(p))
where P = Cylinder Pressure (psi)
Patm = Atmospheric Pressure (psi)
A = Piston Crown Area (mm^2)
r = Crankshaft Radius (mm)
a = Crankshaft Angle (deg)
p = Piston-Rod Angle (deg)
What are you using that equation to plot? What units do you think it should be in?
It plots the pressure contribution of the cylinder.
Hmm, I'm not comprehending something here.
Are you asking what the unit of the equation you wrote are in?
Yes. I'm confused because the pressure volume diagram plots cylinder pressure as Newtons/meter/meter, Which I think is megaPascals, and now somehow the pressure contribution, Inertia contribution, and Turning Moment are all in Newton Meters.
I think ultimately you need to be much more careful with your units as Nidum said. Note pressure as N/m^2 rather than N/m/m (which is confusing).
The answer is all in the equation. Ignore units for now and conceptually break down the equation into steps.
What is happening at each step:
1. (P-Patm)
2. (P-Patm)*A
3. ((P-Patm)*A)*r
What do the cos and sin terms do to this?
Or try doing this from first principles to gain a conceptual understanding. We are plotting torque yes?
T=F*d
So how to F and d change as we go through the engine cycle? Start with d first.
1. (P-Patm)
2. (P-Patm)*A
3. ((P-Patm)*A)*r
T=F*d
So far, this is what iv'e got:
(P-Patm)
Where
P= Cylinder Pressure (atm)
P= Atmospheric Pressure (atm)
atm–atm=atm
atm*A
Where A= Piston Cross Sectional Area (mm^2)
atm*mm^2= atm*mm^2
atm*mm^2*r
Where r= Crankshaft Radius (mm)
atm*mm^2*mm= atm*mm^3
Now this is were things start to get looney
atm*mm^3*(sin(ac+acr)/cosine(acr))
Where
ac= crank angle
acr = angle between bore centerline and connecting rod
You need to abstract away from the units. They are actually irrelevant to what's going on.
1. Is net (gauge) cylinder pressure. Can be Psi, Bar, atm, MPa, whatever.
2. Pressure * area = ?
3. ^_^ * distance = ?
Draw the crank throw and conrod vertical. If you apply pressure here, what rotating torque do you have?
The proper phasing depends upon the geometry of the engine, specifically (1) the relative crank angles and (2) the relative cylinder inclination angles (in-line, V, opposed, etc). All of this goes into the kinematics that relate one reference crank angle to the effective crank angle for each other cylinder.
Depending on the purpose for the analysis, it may, or may not, be appropriate to simple add the torques from all cylinders.
(1) If the crank is to be considered rigid, then all of the torques are additive.
(2) If the crank is to be considered as flexible, as is necessary for a torsional vibration analysis of the machine, then each cylinder torque should be considered as a separate excitation, with appropriate phasing.
at 360°, where pressure=atm, area=mm^2, and distance= mm, I have 85864 atm's*mm^3
You're missing the point of what I'm asking and seemingly blindly applying an equation you have found. To understand properly you need to know how to derive the equation for torque.
Draw(or google) the picture of a crank slider with the piston at TDC.
Ignore the values and the figure on the right please.
So in that left hand image, imagine we apply maximum cylinder pressure (as happens at TDC on an ideal otto cycle). At that instant, how much torque does it make?
I can't specify... :frown:
You can, its one of the cases where you don't need to see any units or values.
If torque = force * distance?
Force acts vertically downwards, what is th length of the moment arm?
One meter.
I'm afraid not. The answer is zero; no moment arm, no torque. Can you see why?
does it have to do with the fact that the crank angle is zero?
It does indeed. You are still applying the force on the piston though.
If it's not making torque what is it doing?
well I know this:
When you generate torque on a static (non-moving/no velocity of any kind) Object, You are still indeed applying torque, but you are not generating any WORK. Correct?
The force is bending the crank. The thing to take away from this is that for every crank angle. The force acting vertically down resolved into a bending component and a turning component.
Much in the same way that gravity on an inclined plane resolves into a normal and perpendicular force.
There are inertial terms arising from both the piston acceleration and the connecting rod (linear and angular) acceleration. These are not constants, and are phased to be associated with each cylinder in turn.
This difficulty with the slider-crank machine is largely due to the kinematics. If you have a good device to handle the kinematics, then the correct equation for every cylinder is easily written using energy methods. This will have every cylinder moving in its proper phase, with the associated terms due to piston and connecting rod motion. To try to cobble together torque functions, etc. on an ad hoc basis is just asking for trouble.
Yeah, the equations support this. Now, what I'm TRYING to figure out is how to get from (atm*mm^3+kg*degree/mm) to Newton Meters.
I'm sorry I'm probably frustrating you a lot.
:frown:
:cry:
*Note: the above graph is an approximation.
Jason,
Thanks for the msg and I'll be answering soon but Chris and others will be helping you from here on.
Remember Newton's 3 laws of motion. You're dealing with rotational or angular analogs but they still apply. Body at rest, body in motion stuff. What happens at TDC?
It's also time to take off your "physics" hat and put on your "ME" hat with this project of yours. In physics, torque and moment are interchangeable terms. They are not to an ME. Wikipedia even covers this because it's so often misused.
Torque = (moment of inertia) x (angular acceleration)
Newton gave us this.
Furthermore remember equilibrium or here, "Rotational Equilibrium." At a steady velocity, steady can be zero mph or 100 mph, the net external forces of torque equals zero or the sum of all external torque's equals zero. You are going to have to start breaking things down and putting what you are looking for into context to properly organize and then understand it. But that's alright. It's what makes all this fun and you're doing well. As it was once put also, Chris and others are doing you a solid.
By the way, the compression ratio of your engine is 10:1 or 10.5:1 with VV.
----not everything was here when I wrote this----
:frown:
:cry:
Before you get too far trying to convert this result, check the dimensions of your terms. The first part has atm*mm^3, or pressure x volume. This correctly gives you work units.
However, the second part, in kg*degree/mm, is in mass/distance, which does not make physical sense here.
I would go back and redo the problem, putting everything into SI units, and track the units every step of the way.
Hi guys, Iv'e been SUPER busy the past few weeks so I didn't think about posting for a while. The spreadsheet has gone through a series of MASSIVE updates, But I won't put in multi-cylinder engine support until a few roadblocks are cleared up. For now, I will post this screenshot and upload the spreadsheet for you guys to check out!
