Fortran Can equations be used in Fortran array declarations with parameters?
  • Thread starter Thread starter Matterwave
    Array Fortran
In the discussion, the main focus is on the use of equations in array declarations in Fortran. It clarifies that array bounds must be INTEGER constants, and while constants declared with the PARAMETER statement are acceptable, they must precede the array declaration. The conversation highlights that if 'y' is a parameter, using it in an array declaration like "real, dimension(2*y)::x" is legitimate. The distinction between assignment and equality testing is also emphasized, noting that Fortran uses different symbols for these operations. The clarification that parameters have values known at compile time, allowing the compiler to allocate memory correctly, is a key point. Overall, the discussion confirms that using parameters in array dimensions is valid in Fortran programming.
Matterwave
Hi, I'm just wondering real quick, are equations allowed in array declarations? For example:
int :: y=2
int, dimension(2*y):: x
Technology news on Phys.org
I don't think the equation you have would be permitted, as the array bounds must be INTEGER constants. However, constants declared with the PARAMETER statement are OK for array declarations, as long as the PARAMETER statement precedes the array declaration.
http://star-www.st-and.ac.uk/~spd3/Teaching/AS3013/lectures/AS3013_lecture5.pdf
So even if y were a parameter, probably I still can't do that?
EDIT: I looked at a later part of the lecture and he had something like what I have except y is a parameter. So I think I'm doing OK. Thanks. :)
The whole point of a parameter in Fortran is that the parameter's value is known at compile time, so the compiler knows how much memory to allocate for the array. For a variable (not a parameter), the variable gets its value at run time, I believe.
Minor point. A statement such as y = 2 is an assignment, or in this case an initialization, not an equation. It does not state that y and 2 are equal. Instead, it stores the constant value 2 in the location that is named y.
Most programming languages make distinctions between assignment and testing for equality by using different symbols. For example, Fortran uses .EQ. to test for equality, and uses = for assignment. Languages based on C, such as C++, C#, Java, and others, use == to test for equality and = for assignment. Newer versions of Fortran now support the C-style notation, in addition to the older .EQ., .LT., GT., and other spelled-out relational operators.
Yes, I forgot to include that y is a parameter, and my language is lazy because I'm not a programmer really. Sorry for the confusion. :P
I just wanted to make sure that the statement
is legitimate if y is a parameter, and Steamking's link had something just like that in it.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
