Foundations of measure theory?
tgt
What theory are they?
Set theory comes to mind but is that too broad?
Mathematics news on Phys.org
Your question is somewhat vague. However, measure theory starts with the notion of collections of subsets, of a measurable set, which are closed under countable unions and countable intersections. A measure is then defined as a non-negative function of these subsets, which must follow certain rules. Essentially it has to be countably additive.
Measure theory is a fairly advanced subject, and it falls under the heading of real analysis. You need to be comfortable with basic set theory (as in all math), limits, sequences, series, continuity, convergence, and other topics that you would see in a year long sequence in undergraduate real analysis. Do you have a more specific question?
Here are two good books to start with if you are starting to learn the subject.
https://www.amazon.com/dp/0521097517/?tag=pfamazon01-20 by Alan Weir
https://www.amazon.com/dp/0763717088/?tag=pfamazon01-20 by Frank Jones
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
