MHB Fraction Multiplication: How to Multiply Fractions and Mixed Numbers
To solve the problem of how many boxes of paper remain after giving away half of 3 1/4 boxes, the correct approach involves multiplying by 1/2. The calculation shows that half of 3 1/4 is 1 5/8 boxes. The confusion arises from misunderstanding the multiplication process and the conversion of mixed numbers to improper fractions. The solution can be visualized by breaking down the multiplication into simpler components, confirming that the answer is indeed 1 5/8. Understanding these steps clarifies the process of fraction multiplication and subtraction in this context.
David39ni
I am finding it hard to understand this questions its sounds more like fraction subtraction than multiple but the army test sample questions says its multipication
You have 3 1/4 boxes of paper. You give 1/2 to the paper to a colleague, how many boxes of paper do you have left.
The test says 1 5/8 i don't understand how they get to that. Now when i did prob did it wrong i got 22 / 12 I don't now how they get 1 5/8.
This is not home work this is revision questions available on the site to practise the type of quesitons I might be getting.
Mathematics news on Phys.org
Hello and welcome to MHB, David39ni! (Wave)
If you give away 1/2, then you have 1/2 left. So all we need to do is find what one-half of what you began with is:
$$\frac{1}{2}\cdot3\tfrac{1}{4}=\frac{1}{2}\cdot\frac{3\cdot4+1}{4}=\frac{1}{2}\cdot\frac{13}{4}=\frac{13}{8}=\frac{8+5}{8}=1\tfrac{5}{8}$$
Does that make sense?
Not really sorry wish this site had videos you still don't how their answer what i said ?
I am assuming you understand that if you give half of something away, you are left with one-half yourself.
Another way to look at finding one half of the original amount is:
$$\frac{1}{2}\cdot3\tfrac{1}{4}=\frac{1}{2}\left(3+\frac{1}{4}\right)=1\tfrac{1}{2}+\frac{1}{8}=1\tfrac{4}{8}+\frac{1}{8}=1\tfrac{5}{8}$$
This is actually more in line with how I would picture it mentally. :D
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
