Can an object falling towards a super massive planet reach the speed of light?
In summary, the question is whether a person falling from a great height above a super massive planet with no atmosphere could reach the speed of light due to the gravitational field. The answer is no, as the classical calculation is incorrect for velocities close to the speed of light. This requires the use of special relativity, where the acceleration decreases as the velocity approaches c. However, from the point of view of an observer in freefall, it is possible for objects to have a coordinate velocity greater than c in non-inertial coordinate systems.
Goalie33
33
This question has bothered me for few weeks:
Lets say I was at some height above a super massive planet that has no atmosphere (i.e. no air resistance. If I were to begin falling what would stop me from being accelerated by the gravitational field of this planet to the speed of light? Assume that the mass of the planet and my height above the surface are enough to get me past c (if only the classical calculation is done.)
The classical calculation is incorrect for that scale. You need physics that can deal with velocities close to c, and that requires relativity.
One way to think about it is this. You never get past c because you never get to infinite kinetic energy. No matter how far you fall, there's a finite amount of potential energy involved, according to any stationary observer. (The velocity is going to depend on who is measuring it and with what co-ordinates.)
Cheers -- sylas
F is not equal to ma once you reach relativistic speeds. As you get close to the speed of light your acceleration will decrease, even if the gravitational field does not change. IIRC the result is [tex]F = \gamma^3ma[/tex] [1], where [tex]\gamma[/tex] is the usual Lorentz factor, which gets large as you approach the speed of light, causing the acceleration to get small, so you never actually reach the speed of light.
[1] This is for the force, acceleration and velocity all in the same direction. If you want to work with vectors, then the relation becomes more complex, and depends on the angle between the force and the velocity.
Thanks to both of you,
I understood that it would involve Special Relativity. (I knew classical mechanics would break down, I know now that the comment towards the end was misleading.) I just didn't know how to incorporate SR.
I think I've got it now, thanks again!
what if you use proper acceleration instead?
There are two realities here, one from an observers point of view as described above and one from the person in freefall who is quite unaware of any force acting on him. In his freefalling environment he is quite at liberty to achieve a speed of separation faster than c (relative to his original frame/starting point). For instance, if he was falling towards a black hole, say from near infinity, I would imagine that he would exceed c once past the event horizon.
The speed of light limit is only meant to apply in inertial coordinate systems, even in flat spacetime with no gravity it's quite possible for objects to have a coordinate velocity greater than c if you pick the right non-inertial coordinate system. In GR, no global coordinate system in curved spacetime can ever qualify as inertial, but because of the http://www.aei.mpg.de/einsteinOnline/en/spotlights/equivalence_principle/index.html an observer in freefall who is only paying attention to a small region of spacetime around him can have a "locally inertial" frame in that region where the laws of physics should look the same as in SR (assuming the region is chosen small enough that tidal forces are undetectable), and any objects passing by him in that region will be moving at less than c (or exactly c in the case of photons or other massless particles) in his locally inertial frame.
A general relativistic calculation shows that a body falling from rest at infinity towards a Schwarzschild source, reaches c wrt to the source exactly on the event horizon (!).
See ( for instance ) arXiv:gr-qc/0411060.
1. What is free fall acceleration?
Free fall acceleration is the acceleration an object experiences when it is falling under the sole influence of gravity. This acceleration is constant and equal to 9.8 meters per second squared (m/s^2) near the Earth's surface.
2. What is the value of free fall acceleration on Earth?
The value of free fall acceleration on Earth is approximately 9.8 m/s^2. However, this value can vary slightly due to factors such as altitude and location on Earth.
3. Can an object reach the speed of light (c) during free fall?
No, an object cannot reach the speed of light during free fall. The speed of light is approximately 299,792,458 m/s, which is much faster than the acceleration due to gravity.
4. How does air resistance affect free fall acceleration?
Air resistance can affect free fall acceleration by slowing down the object's descent. This is because air resistance creates an opposing force that acts against the force of gravity, resulting in a slower acceleration.
5. What is the difference between free fall acceleration and terminal velocity?
Free fall acceleration is the constant acceleration an object experiences when it is falling under the sole influence of gravity, while terminal velocity is the maximum velocity an object can reach when the force of air resistance is equal to the force of gravity. In other words, terminal velocity is the point at which an object's acceleration due to gravity is balanced by the opposing force of air resistance, resulting in a constant velocity.
