Thrown vs Dropped Objects: Explained
  • Thread starter Thread starter alyafey22
The discussion clarifies the difference between thrown and dropped objects, emphasizing that a thrown object has an initial velocity due to the force applied by the thrower, while a dropped object starts from rest with zero initial velocity. Both scenarios experience the same gravitational acceleration of 9.8 m/s². The equations of motion apply to both cases, but the initial velocity (v₀) is zero for dropped objects and non-zero for thrown objects. This distinction is crucial for understanding the physics of motion under gravity. The conversation highlights that the terminology used in everyday language reflects this fundamental difference in initial conditions.
alyafey22
MHB
What 's the difference between an object thrown or dropped , does a thrown object treat as a free fall condition ?? if it does
we know that d=v(initial)*t + 1/2a*t^2
and we know that in free falls condition we use the equation d= 1/2g*t^2
that means initial velocity of free falls should be zero and thrown object has an initial velocity ??
can anyone explain to me this , please >>>?
It's hard to make out what you are asking but I think that what you are saying is correct.
If we release (not throw), a ball for instance, on Earth relative to Earth then it's initial velocity is fairly obviously zero. You were just holding the ball before it dropped, it's was not moving relative to you or the earth. It clearly doesn't have any velocity (it's not moving!)
Now if we throw a ball we swing our arm before the ball is released. The ball is moving with our arm but the ball is still moving so when it it released the ball will have some initial velocity
EDIT: In both instances there is the same acceleration (9.8 m/s^2) the only difference is that in the throwing scenario we are giving the ball an starting velocity.
x(t) = x_0 + v_0 t + \frac{g t^2}{2} will work in both cases, but if we drop a ball then v_0=0 in that equation.
Yes...in everyday speaking the difference between 'throwing' and 'dropping' (or 'lifting') is the initial velocity.The first one implies that the initial velocity is not zero while the second implies that it is.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
