Frequency of Vibration of Two Masses Joined by a Spring
The problem involves two masses, ##m_1## and ##m_2##, connected by a spring with a spring constant ##k##. The objective is to determine the frequency of vibration of the masses along the line connecting them, with a specific equation provided for this frequency.
  • Mixed
  • Participants discuss the relationship between the displacements of the two masses and the forces exerted by the spring. There are attempts to derive differential equations of motion for each mass based on their respective displacements.
Several participants have offered guidance on how to set up the equations of motion, emphasizing the importance of considering the spring's elongation based on both masses' positions. There is an ongoing exploration of the relationships between the variables involved, with some participants questioning assumptions and clarifying the setup.
Participants note the need for careful consideration of the spring's behavior when both masses are displaced, as well as the implications of the direction of forces acting on each mass. There is also mention of potential typos in the equations presented, which may affect the clarity of the discussion.
flamespirit919
Two masses ##m_1## and ##m_2## are joined by a spring of spring constant ##k##. Show that the frequency of vibration of these masses along the line connecting them is:
$$\omega =\sqrt{\frac{k(m1+m2)}{m1m2}}$$
##x(t)=Acos(\omega t)##
##\omega =\sqrt{\frac{k}{m}}##
##m\frac{d^2x}{dt^2}=-kx##
So I have that the distance traveled by ##m_1## can be represented by the function ##x_1(t)=Acos(\omega t)## and similarly for the distance traveled by ##m_2## is ##x_2(t)=Bcos(\omega t)##. The force the spring exerts on these two masses is ##−kx_n(t)=m_n\frac{d^2x_n}{dt^2}##. But I have no idea how to relate these functions. Plugging in the values I get the two functions $$-kAcos(\omega t)=-m_1A\omega ^2cos(\omega t)$$ $$-kBcos(\omega t)=-m_2B\omega ^2cos(\omega t)$$
Simplifying I get $$k=m_1\omega ^2$$ $$k=m_2\omega^2$$
But, then I don't know what to do after this or if I am even in the right direction.
You are taking the force on m1 to be -kx1. But the elongation of the spring depends on both x1 and x2, not just x1.
Suppose you say that ##m_1## is displaced to the right by amount ##x_1## from equilibrium and that ##m_2## is also displaced to the right by amount ##x_2## from equilibrium. What is the amount by which the spring is stretched or compressed from equilibrium? Can you write a differential equation of motion for each mass (Newton's 2nd law)?
So would it be $$-k(x_1+x_2)=(m_1+m_2)(\frac{d^2x_1}{dt^2}+\frac{d^2x_2}{dt^2})$$$$-k(Acos(\omega t)+Bcos(\omega t)=(m_1+m_2)(-A\omega ^2cos(\omega t)-B\omega ^2cos(\omega t)$$ Which simplifies to $$k=\omega ^2 (m_1+m_2)$$ But, what can I do with this? Or did I go about this the wrong way?
So would it be $$
-k(x_1+x_2)=(m_1+m_2)(\frac{d^2x_1}{dt^2}+\frac{d^2x_2}{dt^2})$$ ...
No. If, say, ##x_1## = 3 cm and ##x_2 = 5## cm, would the spring be stretched by 8 cm? Draw a picture to scale, first with the spring in equilibrium and then redraw it with one end displaced by 3 units to the right and the other by 5 units also to the right. By how many units is the spring stretched? Knowing the stretching of the spring from equilibrium, gives you the force on each mass. Write separate differential equations for each mass.
The spring would be stretched by 2 units. Would the equations then be $$-k(x_2-x_1)=m_1\frac{d^2x_1}{dt^2}$$$$-k(x_2-x_1)=m_2\frac{d^2x_2}{dt^2}$$
Almost. Does the force of the spring on m1 have the same direction as the force on m2?
No, so would it be $$k(x_2-x_1)=m_1\frac{d^2x_1}{dt^2}$$$$-k(x_2-x_1)=m_2\frac{d^2x_2}{dt^2}$$ Assuming that ##m_1## is on the left and ##m_2## is on the right.
Looks like some typos in your latest equations on the left side. Please check to see if you typed them the way you wanted.
Whoops. They should be fixed now.
Looks good. Can you see a way to solve these equations?
I tried setting them equal to each other $$-m_1A\omega ^2cos(\omega t)=m_2B\omega ^2cos(\omega t)$$ But I end up with $$-m_1A=m_2B$$ I don't know what I can do after this.
OK. This gives you a relation between A and B in the assumptions x1 = Acosωt and x2 = Bcosωt. Try to combine this result with the first differential equation k(x2 - x1) = m1d2x1/dt2.
Thank you! I wasn't sure which equation to plug the values into. Here's what I did $$k(Bcos(\omega t)-Acos(\omega t))=-m_1A\omega ^2cos(wt)$$$$k(Bcos(\omega t)+\frac{m_2B}{m_1}cos(\omega t)=m_2B\omega ^2cos(\omega t)$$$$kBcos(\omega t)(1+\frac{m_2}{m_1})=m_2B\omega ^2cos(\omega t)$$$$k(1+\frac{m_2}{m_1})=m_2\omega ^2$$$$k(m_1+m_2)=m_1m_2\omega ^2$$$$\omega ^2=\frac{k(m_1+m_2)}{m_1m_2}$$$$\omega =\sqrt{\frac{k(m_1+m_2)}{m_1m_2}}$$Did I do all my math right?
Let ##x_1<x_2## be coordinates of masses ##m_1,m_2## respectively. Then
##m_2\ddot x_2=-(x_2-x_1-l)k,\quad m_1\ddot x_1=(x_2-x_1-l)k##, here ##l## is the length of relaxed spring. Divide each equation by corresponding mass and subtract the second equation from the first one
##\ddot\xi=-(k/m_2+k/m_1)\xi+const,\quad \xi=x_2-x_1## so that ##\omega^2=
k/m_2+k/m_1##
Yes, I believe so.
Note that in your approach, you assumed x1 and x2 have time dependences of cosωt. That might be OK.
@zwierz shows how to get a differential equation that directly gives you the frequency without having to make any prior assumptions about the nature of the motion.
