Discover the Frequency of Fingered Violin Strings Without Measuring Length
  • Thread starter Thread starter needhelp83
    Frequency Violin
A violin string vibrates at a fundamental frequency of 294 Hz when unfingered. To find the frequency when the string is fingered one third of the way down, it is suggested to use a variable length, denoted as L, rather than needing the actual measurement. The relationship between frequency and length indicates that the frequency will increase as the vibrating length decreases. The calculations presented show that the frequency at one third of the string's length would be 1176 Hz, which is derived from the fundamental frequency. Understanding the relationship between frequency and string length is crucial for solving this problem effectively.
needhelp83
A violin string vibrates at 294 Hz when unfingered. At what frequency will it vibrate if it is fingered one third of the way down from the end?
How do I determine this w/o length of how far 1/3 of violin string is?
Help anyone!
Hint -- you have the information needed to find the length of the string.
I thought you needed more information to find the length. But in any case...
Why do you think you need to know? Have you considered just calling the length L, and seeing if you can do the problem?
are you familiar with the relation between wavelength and frequency?
also: what is the speed of sound in air?
Does it matter what the actual length is? Surely as Hurkyl points out, length can be simply L. It's merely the freq and the change in length that's important.
f1= 294 Hz (fundamental frequency)
f2= 2f1=(2)( 294 Hz)= 588 Hz
f3= 3f1=(3)( 294 Hz)= 882 Hz
f4= 4f1=(3)( 294 Hz)= 1176 Hz
The 294 Hz would be the fundamental frequency and 1/3 the way down would be 1176. Would this be the correct way to solve?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
