entropy1
- 1,230
- 71
What does a 180 degree phase shift of a sinusoidal in a signal do to the frequency spectrum of the signal?
What do you think and why?entropy1 said:What does a 180 degree phase shift of a sinusoidal in a signal do to the frequency spectrum of the signal?
I think a wield of various harmonics due to the energy in the signal at the phase shift. What I'm interested in is what the frequency spectrum looks like in that case.phinds said:What do you think and why?
We can assume a single sinusoid with a 180 degree phase shift exactly in the middle of the signal.phinds said:OK, so if it get you right, you are talking about a complex waveform and ALL of the various frequencies are magically phase shifted exactly 180 degrees, yes?
Or do you mean that you have a complex waveform and ONE of the components gets phase shifted?
That doesn't answer my questionentropy1 said:We can assume a single sinusoid with a 180 degree phase shift exactly in the middle of the signal.
I think I don't know what you mean then...phinds said:That doesn't answer my question
Do you mean a pure sine wave that has a discontinuity with a sudden phase change?entropy1 said:I think I don't know what you mean then...
FAPP, I mean a dicrete signal with a sinosoid with phase change in it.
Precisely.phinds said:Do you mean a pure sine wave that has a discontinuity with a sudden phase change?
I don't know about entropy1 but that's all Greek to me.Charles Link said:The initial signal has ## \tilde{F}(\omega)=A_o \delta(\omega-\omega_o) ##, and the same signal with a phase shift ## \phi ## has ## \tilde{F}(\omega)=A_o e{\i \phi} \delta(\omega-\omega_o) ##. The energy density ## U(\omega) ## is proportional to ## |\tilde{F}(\omega)|^2 ## and will be the same for both cases. Mathematically, the energy density gets unworkable if it involves the square of a delta function, so there really needs to be some finite bandwidth.
Which signal do you speak of here?Charles Link said:The initial signal
The original signal is ##F(t)=e^{i \omega_o t } ##. It really needs to be modified by a finite bandwidth to be completely workable. Including something like ## e^{-\alpha |t|} ## with small ## \alpha ## can help the mathematics.entropy1 said:Which signal do you speak of here?
So the frequency spectrum contains a delta function, or a single harmonic? (which seems logical)Charles Link said:The original signal is ##F(t)=e^{i \omega_o t } ##. It really needs to be modified by a finite bandwidth to be completely workable.
Logical, but the Fourier transform theory I believe requires the function ## F(t) ## to be square integrable from ## -\infty ## to ## +\infty ##. See the addition I made to the previous post.entropy1 said:So the frequency spectrum contains a delta function, or a single harmonic? (which seems logical)
Oh, maybe I should bephinds said:I thought at first that you were talking about a complex waveform
You could have the two signals be ## F_1(t)=e^{-\alpha |t|} e^{i \omega _o t } ## for ## t<0 ## and ## F_1(t)=0 ## for ## t>0 ##, and ## F_2(t)=e^{i \phi} e^{-\alpha |t|}e^{i \omega_o t} ## for ## t>0 ##, and ## F_2(t)=0 ## for ## t<0 ##. I believe the F.T.'s are quite workable. See this thread, post 2, https://www.physicsforums.com/threa...y-formula-e-iwt-or-e-iwt.952487/#post-6037110 for the definition of Fourier Transform that I like to use. Basically these two will differ by ## e^{i \phi} ## if I'm not mistaken. There may be additional small differences, but the spectral energy density ## U(\omega) ## should be the same for both.entropy1 said:So if the energy density of the first half of the signal and the second half of the signal is the same, the problem arises at the discontinuity, as would be expected?
Then simply superimpose ## F_1(t) ## and ## F_2(t) ## and compute the F.T.entropy1 said:Yes. I want to treat the waveform as a single signal though.
Yes. I did not read you correctly. I thought I could circumvent calculating it by lazily asking the question bluntlyCharles Link said:Then simply superimpose ## F_1(t) ## and ## F_2(t) ## and compute the F.T.
The result of the factor ## e^{- \alpha |t|} ## should be to introduce a bandwidth ## \Delta \omega \approx \alpha ##. I believe I have worked through this, or a very similar calculation, a number of years ago. You can also make the time interval finite from ## -T ## to ## +T ## (large ## T ##), with ## F(t)=0 ## outside of this interval, and you will have a bandwidth ## \Delta \omega \approx \frac{1}{T} ##.entropy1 said:Yes. I did not read you correctly. I thought I could circumvent calculating it by lazyly asking the question bluntly
The frequency spectrum of phase shift is a representation of the different frequencies present in a signal after it has undergone phase shift processing. It shows the amplitude and phase of each frequency component in the signal.
The frequency spectrum of phase shift is measured using a spectrum analyzer, which analyzes the frequency components of a signal and displays them in a graph or plot. It can also be calculated using mathematical equations and algorithms.
Phase shift in a signal can be caused by a variety of factors, including changes in the medium through which the signal passes, changes in the properties of the signal itself, and external interference or manipulation of the signal.
Phase shift can alter the frequency spectrum of a signal by changing the relative phases and amplitudes of its different frequency components. This can result in a distortion of the original signal and the introduction of new frequency components.
The frequency spectrum of phase shift is important in signal processing because it can provide valuable information about the properties and characteristics of a signal. It is used in various applications such as communication systems, audio and video processing, and medical imaging.
